[問題]如何才能再做下一步
寒冰軒
文章: 417
註冊時間: 2003-11-06 23:24
來自: 阿婆A灶腳
[問題]如何才能再做下一步
文章 由 寒冰軒 »
各位大大我在教學文件庫中的
http://phpbb-tw.net/phpbb/viewtopic.php ... highlight=
這一文
己按照上面所教的步驟安裝
但要做到步驟5時一直都沒出現英文網站
都一直出現ie錯誤網頁↓
The page cannot be displayed
The page you are looking for is currently unavailable. The site might be experiencing technical difficulties, or you may need to adjust your browser settings.
Choose your topic of interest:
Business
Cars
Computers
Electronics
Entertainment
Finance
Free
Gambling
Home
Office
Shopping
Travel
Enter keyword:
Please try the following:
Click the Refresh button, or try again later.
If you typed the page address in the Address bar, make sure that it is spelled correctly.
To check your connection settings, click the Tools menu, and then click Internet Options. On the Connections tab, click Settings. The settings should match those provided by your local area network (LAN) administrator or Internet service provider (ISP).
Some sites require 128-bit connection security. Click the Help button and then click About Internet Explorer to determine what strength security you have installed.
If you are trying to reach a secure site,make sure your Security settings can support it. Click the Tools menu, and then click Internet Options. On the Advanced tab, scroll to the Security section and check settings for SSL 2.0, SSL 3.0, TLS 1.0, PCT 1.0.
Click the Back button to try another link.
Cannot find server or DNS Error
Internet Explorer
請問我該如何處理呢\r
我己有重新安裝1x次了
但都只能做完第四個步驟
請各位大大們幫個忙唷\r
謝謝大家
Martinet
文章: 850
註冊時間: 2003-06-09 21:58
文章 由 Martinet »
試試看下面這幾個連結呢?
http://localhost/phpbb/install/install.php
或
http://localhost/phpbb2/install/install.php
小竹子那篇教學好像是舊版的 , 新版的安裝位置改變了 , 但是竹子的教學還沒修正^^"
寒冰軒
文章: 417
來自: 阿婆A灶腳
文章 由 寒冰軒 »
先謝謝上面的大大幫我解決了步驟5的問題
第二個網址我可以進去了
但是要開始安裝時又出現錯誤嚕
出現↓
phpBB : Critical Error
^^" 又要再一次麻煩大大們幫忙解答一下
謝謝唷~ 辛苦嚕
寒冰軒
文章: 417
來自: 阿婆A灶腳
[問題]
文章 由 寒冰軒 »
Your Database Name:phpbb<--看你建立的資料庫名稱為何,lycos.co.uk 的免費空間則是填入 你所申請的帳號_uk_db
Database Username:<--看你建立的資料庫管理帳號為何,lycos.co.uk 的免費空間則是填入 你所申請的帳號
Database Password:<--看你建立的資料庫管理密碼為何,lycos.co.uk 的免費空間則是填入 你所申請該帳號的密碼
^^" 還有想再請教一下 文章中的 lycos.co.uk 和 你所申請的帳號_uk_db
這兩句是什麼意思呢?
是要輸入那一個帳號和密碼呢?
如果是輸入申請空間時的網站的帳號和密碼\r
那是不是就是話我申請的空間是 pc home 的免費空間
我是不是就要輸入pc home的會員帳號和密碼呢?
↑以上是我自己想的 等待大大們幫忙解答↑
謝謝大大們~ ^^
寒冰軒
文章: 417
來自: 阿婆A灶腳
[問題]
文章 由 寒冰軒 »
^^" 嗚嗚
我現在卡在\r
第八個步驟
一直不能到第九個步驟(安裝完成)這個步驟耶\r
一直卡在網頁中(開始安裝)這個步驟
在教學文中的第八個步驟
其中的這三格是要輸入什麼呢?
您的資料庫名稱:
資料庫使用者帳號:
資料庫密碼 :
請問各位大大能幫忙解答一下哦\r
謝謝唷~ ^^ 辛苦了
jiminkao
文章: 134
註冊時間: 2002-10-07 15:20
來自: 蜂炮之鄉
文章 由 jiminkao »
pc home 的免費空間有提供 php 和 mysql 的環境嗎?
如無,則無法安裝 phpbb2。
目前使用版本 Nuke7.6
寒冰軒
文章: 417
來自: 阿婆A灶腳
[問題]
文章 由 寒冰軒 »
抱歉
再請問一下
網域名稱: ← 這一格要輸入什麼呢\r
謝謝唷
寒冰軒
文章: 417
來自: 阿婆A灶腳
文章 由 寒冰軒 »
查了一下pc home 和giga都沒提供php的環境耶\r
那可以請問一下我應該要到那兒申請有提供php環境的空間呢?
謝謝幫忙
逍遙悠
文章: 313
註冊時間: 2002-11-30 16:57
來自: 遙遠的那一端
文章 由 逍遙悠 »
寒冰軒 寫:>"<
謝謝幫忙
1.付費租用 php空間
2.免費空間 但是已經很難申請了 步驟一大堆
3.找個認識的網友 請他提供空間給你架設ㄅ
