[問題]sql語法
bu
文章: 443
註冊時間: 2003-02-23 12:46
來自: 25° 4′N 121° 29′E
文章 bu »
用這段試試 ^^
DROP TABLE  IAI_BOT_T;
DROP TABLE  IAI_CONVO_T ;
DROP TABLE  IAI_DSTORE_T;
DROP TABLE  IAI_PATERN_T;
DROP TABLE  IAI_TEMPLATE_T;
DROP TABLE  IAI_THATIDEX_T;
DROP TABLE  IAI_THATSTACK_T;
DROP TABLE  IAI_GMCACHE_T;
ALTER TABLE  FORUMS_TABLE  DROP iai_override;
ALTER TABLE  FORUMS_TABLE  DROP iai_percentage;
ALTER TABLE  FORUMS_TABLE  DROP iai_stop_words;
DELETE FROM  phpbb_config  WHERE config_name = 'iai_active_all';
DELETE FROM  phpbb_config  WHERE config_name = 'iai_active_pm';
DELETE FROM  phpbb_config  WHERE config_name = 'iai_percentage_all;
DELETE FROM  phpbb_config  WHERE config_name = 'iai_username';
DELETE FROM  phpbb_config  WHERE config_name = 'iai_userid'
DELETE FROM  phpbb_config  WHERE config_name = 'iai_respond_words';
DELETE FROM  phpbb_config  WHERE config_name = 'iai_active_wpm';
phpbb_config 可能會有所不同,請先檢查
*譯文資料在phpBB 技術文件
bu.femto-size
*和我聯絡,請寄 or Google Talk 圖檔
