問題外掛:N/A
參考連結:N/A
使用版本:phpbb 2.0.10
網站位置:因為公司用途,所以不更公開,敬請原諒‧
狀況描述:不知甚麼原因做會出現已下的Error Message,請各位大大幫幫小弟呢 >.<
Could not delete group for this user
SQL Error : 1064 You have an error in your SQL syntax. Check the manual that corresponds to your MySQL server version for the right syntax to use near '' at line 2
DELETE FROM phpbb_groups WHERE group_id =
Line : 256
File : c:\appserv\www\phpbb2\admin\admin_userlist.php
[問題] 請問SQL版本不夾會導致這個問題呢?
