[問題]php 4.3.6升級至 4.3.10 時 就無法登入
izumonoenishi
註冊時間: 2004-12-06 10:06
文章 izumonoenishi »
session_start();
header ( );
這兩個函數會出現錯誤
並出現\r
Warning: Unknown(): Your script possibly relies on a session side-effect which existed until PHP 4.2.3. Please be advised that the session extension does not consider global variables as a source of data, unless register_globals is enabled. You can disable this functionality and this warning by setting session.bug_compat_42 or session.bug_compat_warn to off, respectively. in Unknown on line 0
登入 登出完全沒動作 :cry:
是不是什麼地方沒有設定好??
第一次做升級的動作~~不知道該怎麼辦...
那位大大可以幫忙解惑~~~感激不盡
文章 小竹子 »
