◎上網方式:學術網\r
◎安裝的程式:IIS6x + ODBC_ACCESS
◎phpBB2版本:2.0.17
◎domainl:SFWPRO.com
◎phpBB2網址:http://phpbb.sfwpro.com
◎以上備註,論壇上的設置及安裝上是沒有任何問題滴!!
目前測試全新的 2.0.17 版本資料庫採用 MS ACCESS.
完工後實測發生的問題,下面提出. (該問題僅在ACCESS上出現)
在文章發表中寫入特定字元如下:(這個錯誤是"一"字元出現)
測試一下~~代碼: 選擇全部
Warning: odbc_exec() [function.odbc-exec]: SQL error: [Microsoft][ODBC Microsoft Access Driver] 查詢運算式 'word_text IN ('測試', '測試?)' 中的 字串語法錯誤。, SQL state 37000 in SQLExecDirect in C:\Server_Files\php_demo\db\msaccess.php on line 120
Warning: Cannot modify header information - headers already sent by (output started at C:\Server_Files\php_demo\db\msaccess.php:120) in C:\Server_Files\php_demo\includes\page_header.php on line 475
Warning: Cannot modify header information - headers already sent by (output started at C:\Server_Files\php_demo\db\msaccess.php:120) in C:\Server_Files\php_demo\includes\page_header.php on line 477
Warning: Cannot modify header information - headers already sent by (output started at C:\Server_Files\php_demo\db\msaccess.php:120) in C:\Server_Files\php_demo\includes\page_header.php on line 478
& #28204;& #35430;& #19968;& #19979;~~該問題已經解決,方法如下:
開啟 includes\functions_search.php 文件 92~103行修正如下.
英文的部份是說,若是有問題的話請修改如下.
function split_words(&$entry, $mode = 'post')
// If you experience problems with the new method, uncomment this block.
$rex = ( $mode == 'post' ) ? "/\b([\w±µ-ÿ][\w±µ-ÿ']*[\w±µ-ÿ]+|[\w±µ-ÿ]+?)\b/" : '/(\*?[a-z0-9±µ-ÿ]+\*?)|\b([a-z0-9±µ-ÿ]+)\b/';
preg_match_all($rex, $entry, $split_entries);
return $split_entries[1];
// Trim 1+ spaces to one space and split this trimmed string into words.
//return explode(' ', trim(preg_replace('#\s+#', ' ', $entry)));
