[問題] 論壇註冊出現問題
choppy
文章: 76
註冊時間: 2005-05-18 10:13
來自: hong kong
[問題] 論壇註冊出現問題
文章 choppy »
●架設主機作業系統:Linux
●您的上網方式:ADSL (網上行寬頻)
●您安裝的程式:Apache + php + MySql
●您的 phpBB2 版本:phpBB2.0.17
●您的 domain(網域名稱) :http://www.longlastingrock.com
●您的 phpBB2 連結網址:http://www.longlastingrock.com/phpbb/index.php
●錯誤代碼:
<?php
 *                                index.php
 *   $Id: index.php,v 1.99.2.3 2004/07/11 16:46:15 acydburn Exp $
define('IN_PHPBB', true);
$phpbb_root_path = './';
// Start session management
init_userprefs($userdata);
// End session management
$viewcat = ( !empty($HTTP_GET_VARS[POST_CAT_URL]) ) ? $HTTP_GET_VARS[POST_CAT_URL] : -1;
if( isset($HTTP_GET_VARS['mark']) || isset($HTTP_POST_VARS['mark']) )
	$mark_read = ( isset($HTTP_POST_VARS['mark']) ) ? $HTTP_POST_VARS['mark'] : $HTTP_GET_VARS['mark'];
	$mark_read = '';
// Handle marking posts
if( $mark_read == 'forums' )
		setcookie($board_config['cookie_name'] . '_f_all', time(), 0, $board_config['cookie_path'], $board_config['cookie_domain'], $board_config['cookie_secure']);
	$template->assign_vars(array(
		"META" => '<meta http-equiv="refresh" content="3;url='  .append_sid("index.$phpEx") . '">')
	$message = $lang['Forums_marked_read'] . '<br /><br />' . sprintf($lang['Click_return_index'], '<a href="' . append_sid("index.$phpEx") . '">', '</a> ');
// End handle marking posts
$tracking_topics = ( isset($HTTP_COOKIE_VARS[$board_config['cookie_name'] . '_t']) ) ? unserialize($HTTP_COOKIE_VARS[$board_config['cookie_name'] . "_t"]) : array();
$tracking_forums = ( isset($HTTP_COOKIE_VARS[$board_config['cookie_name'] . '_f']) ) ? unserialize($HTTP_COOKIE_VARS[$board_config['cookie_name'] . "_f"]) : array();
// If you don't use these stats on your index you may want to consider
// removing them
$total_posts = get_db_stat('postcount');
$total_users = get_db_stat('usercount');
$newest_userdata = get_db_stat('newestuser');
$newest_user = $newest_userdata['username'];
$newest_uid = $newest_userdata['user_id'];
if( $total_posts == 0 )
	$l_total_post_s = $lang['Posted_articles_zero_total'];
else if( $total_posts == 1 )
	$l_total_post_s = $lang['Posted_article_total'];
	$l_total_post_s = $lang['Posted_articles_total'];
if( $total_users == 0 )
	$l_total_user_s = $lang['Registered_users_zero_total'];
else if( $total_users == 1 )
	$l_total_user_s = $lang['Registered_user_total'];
	$l_total_user_s = $lang['Registered_users_total'];
// Start page proper
$sql = "SELECT c.cat_id, c.cat_title, c.cat_order
	FROM " . CATEGORIES_TABLE . " c
	ORDER BY c.cat_order";
	message_die(GENERAL_ERROR, 'Could not query categories list', '', __LINE__, __FILE__, $sql);
$category_rows = array();
while( $category_rows[] = $db->sql_fetchrow($result) );
$db->sql_freeresult($result);
if( ( $total_categories = count($category_rows) ) )
	// Define appropriate SQL
	switch(SQL_LAYER)
		case 'postgresql':
			$sql = "SELECT f.*, p.post_time, p.post_username, u.username, u.user_id
				FROM " . FORUMS_TABLE . " f, " . POSTS_TABLE . " p, " . USERS_TABLE . " u
				WHERE p.post_id = f.forum_last_post_id
					AND u.user_id = p.poster_id
					UNION (
						SELECT f.*, NULL, NULL, NULL, NULL
						WHERE NOT EXISTS (
							SELECT p.post_time
							FROM " . POSTS_TABLE . " p
					ORDER BY cat_id, forum_order";
			break;
		case 'oracle':
				WHERE p.post_id = f.forum_last_post_id(+)
					AND u.user_id = p.poster_id(+)
			break;
		default:
				FROM (( " . FORUMS_TABLE . " f
				LEFT JOIN " . POSTS_TABLE . " p ON p.post_id = f.forum_last_post_id )
				LEFT JOIN " . USERS_TABLE . " u ON u.user_id = p.poster_id )
			break;
		message_die(GENERAL_ERROR, 'Could not query forums information', '', __LINE__, __FILE__, $sql);
	$forum_data = array();
		$forum_data[] = $row;
	if ( !($total_forums = count($forum_data)) )
		message_die(GENERAL_MESSAGE, $lang['No_forums']);
	// Obtain a list of topic ids which contain
	// posts made since user last visited
		$sql = "SELECT t.forum_id, t.topic_id, p.post_time
			FROM " . TOPICS_TABLE . " t, " . POSTS_TABLE . " p
			WHERE p.post_id = t.topic_last_post_id
				AND p.post_time > " . $userdata['user_lastvisit'] . "
				AND t.topic_moved_id = 0";
			message_die(GENERAL_ERROR, 'Could not query new topic information', '', __LINE__, __FILE__, $sql);
		$new_topic_data = array();
		while( $topic_data = $db->sql_fetchrow($result) )
			$new_topic_data[$topic_data['forum_id']][$topic_data['topic_id']] = $topic_data['post_time'];
	// Obtain list of moderators of each forum
	// First users, then groups ... broken into two queries
	$sql = "SELECT aa.forum_id, u.user_id, u.username
		FROM " . AUTH_ACCESS_TABLE . " aa, " . USER_GROUP_TABLE . " ug, " . GROUPS_TABLE . " g, " . USERS_TABLE . " u
		WHERE aa.auth_mod = " . TRUE . "
			AND g.group_single_user = 1
			AND ug.group_id = aa.group_id
			AND g.group_id = aa.group_id
			AND u.user_id = ug.user_id
		GROUP BY u.user_id, u.username, aa.forum_id
		ORDER BY aa.forum_id, u.user_id";
		message_die(GENERAL_ERROR, 'Could not query forum moderator information', '', __LINE__, __FILE__, $sql);
	$forum_moderators = array();
		$forum_moderators[$row['forum_id']][] = '<a href="' . append_sid("profile.$phpEx?mode=viewprofile&" . POST_USERS_URL . "=" . $row['user_id']) . '">' . $row['username'] . '</a>';
	$sql = "SELECT aa.forum_id, g.group_id, g.group_name
			AND g.group_single_user = 0
			AND g.group_type <> " . GROUP_HIDDEN . "
		GROUP BY g.group_id, g.group_name, aa.forum_id
		ORDER BY aa.forum_id, g.group_id";
		$forum_moderators[$row['forum_id']][] = '<a href="' . append_sid("groupcp.$phpEx?" . POST_GROUPS_URL . "=" . $row['group_id']) . '">' . $row['group_name'] . '</a>';
	// Find which forums are visible for this user
	$is_auth_ary = array();
	$is_auth_ary = auth(AUTH_VIEW, AUTH_LIST_ALL, $userdata, $forum_data);
	// Start output of page
	define('SHOW_ONLINE', true);
	$page_title = $lang['Index'];
	'top5' => 'top5.tpl',
	'body' => 'index_body.tpl')
	if ( $board_config['allow_top5'] && $userdata['session_logged_in'])
	$template->assign_block_vars('switch_top5_allowed', array());
		'TOTAL_POSTS' => sprintf($l_total_post_s, $total_posts),
		'TOTAL_USERS' => sprintf($l_total_user_s, $total_users),
		'NEWEST_USER' => sprintf($lang['Newest_user'], '<a href="' . append_sid("profile.$phpEx?mode=viewprofile&" . POST_USERS_URL . "=$newest_uid") . '">', $newest_user, '</a>'),
		'FORUM_IMG' => $images['forum'],
		'FORUM_NEW_IMG' => $images['forum_new'],
		'L_TOP5_NEWEST' => $lang['top5_newest'],
	    'L_TOP5_VIEWS' => $lang['top5_views'],
   	    'L_TOP5_REPLIES' => $lang['top5_replies'],
		'L_FORUM' => $lang['Forum'],
		'L_TOPICS' => $lang['Topics'],
		'L_REPLIES' => $lang['Replies'],
		'L_VIEWS' => $lang['Views'],
		'L_POSTS' => $lang['Posts'],
		'L_LASTPOST' => $lang['Last_Post'],
		'L_NO_NEW_POSTS' => $lang['No_new_posts'],
		'L_NEW_POSTS' => $lang['New_posts'],
		'L_NO_NEW_POSTS_LOCKED' => $lang['No_new_posts_locked'],
		'L_NEW_POSTS_LOCKED' => $lang['New_posts_locked'],
		'L_ONLINE_EXPLAIN' => $lang['Online_explain'],
		'L_MODERATOR' => $lang['Moderators'],
		'L_FORUM_LOCKED' => $lang['Forum_is_locked'],
		'L_MARK_FORUMS_READ' => $lang['Mark_all_forums'],
		'U_MARK_READ' => append_sid("index.$phpEx?mark=forums"))
		include($phpbb_root_path . 'includes/functions_top5.php');
$template->assign_var_from_handle('TOP5', 'top5');
	// Okay, let's build the index
	for($i = 0; $i < $total_categories; $i++)
		$cat_id = $category_rows[$i]['cat_id'];
		// Should we display this category/forum set?
		$display_forums = false;
		for($j = 0; $j < $total_forums; $j++)
			if ( $is_auth_ary[$forum_data[$j]['forum_id']]['auth_view'] && $forum_data[$j]['cat_id'] == $cat_id )
				$display_forums = true;
		// Yes, we should, so first dump out the category
		// title, then, if appropriate the forum list
		if ( $display_forums )
			$template->assign_block_vars('catrow', array(
				'CAT_ID' => $cat_id,
				'CAT_DESC' => $category_rows[$i]['cat_title'],
				'U_VIEWCAT' => append_sid("index.$phpEx?" . POST_CAT_URL . "=$cat_id"))
			if ( $viewcat == $cat_id || $viewcat == -1 )
					if ( $forum_data[$j]['cat_id'] == $cat_id )
						$forum_id = $forum_data[$j]['forum_id'];
						if ( $is_auth_ary[$forum_id]['auth_view'] )
							if ( $forum_data[$j]['forum_status'] == FORUM_LOCKED )
								$folder_image = $images['forum_locked'];
								$folder_alt = $lang['Forum_locked'];
								$unread_topics = false;
									if ( !empty($new_topic_data[$forum_id]) )
										$forum_last_post_time = 0;
										while( list($check_topic_id, $check_post_time) = @each($new_topic_data[$forum_id]) )
											if ( empty($tracking_topics[$check_topic_id]) )
												$unread_topics = true;
												$forum_last_post_time = max($check_post_time, $forum_last_post_time);
												if ( $tracking_topics[$check_topic_id] < $check_post_time )
										if ( !empty($tracking_forums[$forum_id]) )
											if ( $tracking_forums[$forum_id] > $forum_last_post_time )
										if ( isset($HTTP_COOKIE_VARS[$board_config['cookie_name'] . '_f_all']) )
											if ( $HTTP_COOKIE_VARS[$board_config['cookie_name'] . '_f_all'] > $forum_last_post_time )
								$folder_image = ( $unread_topics ) ? $images['forum_new'] : $images['forum'];
								$folder_alt = ( $unread_topics ) ? $lang['New_posts'] : $lang['No_new_posts'];
							$posts = $forum_data[$j]['forum_posts'];
							$topics = $forum_data[$j]['forum_topics'];
\n							if ( $forum_data[$j]['forum_last_post_id'] )
								$last_post_time = create_date($board_config['default_dateformat'], $forum_data[$j]['post_time'], $board_config['board_timezone']);
								$last_post = $last_post_time . '<br />';
								$last_post .= ( $forum_data[$j]['user_id'] == ANONYMOUS ) ? ( ($forum_data[$j]['post_username'] != '' ) ? $forum_data[$j]['post_username'] . ' ' : $lang['Guest'] . ' ' ) : '<a href="' . append_sid("profile.$phpEx?mode=viewprofile&" . POST_USERS_URL . '='  . $forum_data[$j]['user_id']) . '">' . $forum_data[$j]['username'] . '</a> ';
								$last_post .= '<a href="' . append_sid("viewtopic.$phpEx?"  . POST_POST_URL . '=' . $forum_data[$j]['forum_last_post_id']) . '#' . $forum_data[$j]['forum_last_post_id'] . '"><img src="' . $images['icon_latest_reply'] . '" border="0" alt="' . $lang['View_latest_post'] . '" title="' . $lang['View_latest_post'] . '" /></a>';
								$last_post = $lang['No_Posts'];
							if ( count($forum_moderators[$forum_id]) > 0 )
								$l_moderators = ( count($forum_moderators[$forum_id]) == 1 ) ? $lang['Moderator'] : $lang['Moderators'];
								$moderator_list = implode(', ', $forum_moderators[$forum_id]);
								$l_moderators = '&nbsp;';
								$moderator_list = '&nbsp;';
							$template->assign_block_vars('catrow.forumrow',	array(
								'ROW_CLASS' => $row_class,
								'FORUM_FOLDER_IMG' => $folder_image,
								'FORUM_NAME' => $forum_data[$j]['forum_name'],
								'FORUM_DESC' => $forum_data[$j]['forum_desc'],
								'POSTS' => $forum_data[$j]['forum_posts'],
								'TOPICS' => $forum_data[$j]['forum_topics'],
								'LAST_POST' => $last_post,
								'MODERATORS' => $moderator_list,
								'L_MODERATOR' => $l_moderators,
								'L_FORUM_FOLDER_ALT' => $folder_alt,
								'U_VIEWFORUM' => append_sid("viewforum.$phpEx?" . POST_FORUM_URL . "=$forum_id"))
	} // for ... categories
}// if ... total_categories
// Generate the page
$template->pparse('body');
●錯誤狀態:
我的論壇註冊發生了問題,新的會員不能註冊,當按"我同意以上條文(而且我已滿13歲)"後,便出現下圖的問題,"很抱歉!! 您所選擇的會員名稱已被註冊使用".
請是什麼問題呢??
救命~~~~
●架設主機作業系統:linux
●上網方式:網上行寬頻
●安裝的程式:Apache + php + MySql+phpMyAdmin
●您的 phpBB2 版本:phpBB (2.0.19)
●您的 phpBB2 連結網址: http://www.longlastingrock.com/phpbb/index.php
choppy
文章: 76
來自: hong kong
文章 choppy »
剛剛發現另一個問題,首頁沒有顯示訪客人數....只有" 0 "
●架設主機作業系統:linux
●上網方式:網上行寬頻
文章: 8536
choppy
文章: 76
來自: hong kong
文章 choppy »
:oops: 解決了!!!衷心感謝~~
●架設主機作業系統:linux
●上網方式:網上行寬頻
eric58889
註冊時間: 2003-02-06 09:45
文章 eric58889 »
解決了!!!衷心感謝~~ :oops: :oops:
您真是太強了...Thanks...
