[問題] 2.0.17→2.0.18 手動修改升級檔案官方下載點(已解決~)
*tytsim*
文章: 411
註冊時間: 2005-03-24 11:54
來自: 香港
文章 *tytsim* »
掛了.....
____________________________
I removed the package because we forgot to include a changed file (usercp_register.php). The packages are updated, but we need to update the code changes too. Then, we will post a reply to the announcement about the repackage.
 網絡鎮
    關於網絡的
http://tytsim.net.ru  一個網絡鎮
問題狂
文章: 1947
註冊時間: 2004-06-28 17:13
文章 問題狂 »
剛剛測試時已經修復
