<!-- BEGIN xxxxxx-->及<!-- END xxxxxx -->這個不是HTML語法, 而是樣版(template)用來識別區塊(block)開始及結束區域的依據
底下用subSilver風格為例
#--------[ OPEN ]----------------
includes/page_header.php
// Obtain number of new private messages
// if user is logged in
#--------[ AFTER, ADD ]----------------
if (!$board_config['privmsg_disable'])
$template->assign_block_vars('switch_enable_pm_menu', array());
if ( !empty($userdata['user_popup_pm']) )
#--------[ REPLACE WITH ]----------------
if ( !empty($userdata['user_popup_pm']) && !$board_config['privmsg_disable'] )
templates/subSilver/overall_header.tpl
<td height="25" align="center" valign="top" nowrap="nowrap"><span class="mainmenu"> <a href="{U_PROFILE}" class="mainmenu"><img src="templates/subSilver/images/icon_mini_profile.gif" width="12" height="13" border="0" alt="{L_PROFILE}" hspace="3" />{L_PROFILE}</a> <a href="{U_PRIVATEMSGS}" class="mainmenu"><img src="templates/subSilver/images/icon_mini_message.gif" width="12" height="13" border="0" alt="{PRIVATE_MESSAGE_INFO}" hspace="3" />{PRIVATE_MESSAGE_INFO}</a> <a href="{U_LOGIN_LOGOUT}" class="mainmenu"><img src="templates/subSilver/images/icon_mini_login.gif" width="12" height="13" border="0" alt="{L_LOGIN_LOGOUT}" hspace="3" />{L_LOGIN_LOGOUT}</a> <a href="{U_DOWNLOAD}" class="mainmenu">{DOWNLOADS_IMG}{L_DOWNLOAD}</a> </span></td>
<!-- BEGIN switch_enable_pm_menu -->
<!-- END switch_enable_pm_menu -->
#--------[ SAVE/CLOSE ALL FILES]----------------
# EoM
tpl 的部份是將這一段私人訊息的部份切到下一行去\r
並在它的前後加上這兩行
這兩行必須自已獨立成一行, 不然會有其它預期外的狀況產生)
