[問題] 請問回覆通知信中的回覆者名字該如何加入 ?
如題
我的是 RC3
在收到回覆通知信時如果想知道對方 ( 回覆者 ) 的名字
該加些甚麼呢?
在那裡加?
因為我想在信中就能先知道是誰所回覆的 ....
我的是 RC3
該加些甚麼呢?
在那裡加?
Niels Chr. Denmark
Posted: Thu Jan 17, 2002 2:56 am Post subject: HACK - Replyers name in "Reply Notification" email posible
I think it is usefull for the users to know by whom, the reply is made, when they recive a email notification.
Therefor I have looked into the code of "POSTING.PHP", and added this line rigth after "TOPIC_TITLE, => $topic_title," like this
"TOPIC_TITLE" => $topic_title,
"REPLY_BY"=> $userdata['username'],
this way I'm able of altering the replyers name in the email template, this has the effect that the user will additionaly get the name of the person who made the reply
this is done by altering the file "TOPIC_NOTIFY.TPL" in the langues/email dir
I have then changed the file to something like this
"...This topic has received a reply from "{REPLY_BY}" since your..."
This litel hack is fully backward compatible, so if you dicide only to apply the hack to a specific language it doesen't matter with the rest
- please fell free to comment , if you don't like it fell also free not to use it
OOHOO said:
有事Mail給我, 不要P我, 因為根本沒辦法P.
不行哩\r
我用這樣的
$template->assign_vars(array(
"REPLY_BY" => $userdata['username'],
"POST_SUBJECT" => $preview_subject,
"POSTER_NAME" => $preview_username,
"POST_DATE" => create_date($board_config['default_dateformat'], time(), $board_config['board_timezone']),
"MESSAGE" => $preview_message,
這個 {REPLY_BY} 也加在 topic_notify.tpl 了
還是不行
請指教
我用這樣的
還是不行
請指教
先在 includes/post.php 找到這陀
[php]<?php
// Handle user notification on new post
function user_notification($mode, &$post_data, &$forum_id, &$topic_id, &$post_id, &$notify_user)
global $HTTP_SERVER_VARS, $HTTP_ENV_VARS;
global $board_config, $lang, $db, $phpbb_root_path, $phpEx;
global $userdata, $user_ip;
$current_time = time();
if ( $mode == "delete" )
$delete_sql = ( !$post_data['first_post'] && !$post_data['last_post'] ) ? " AND user_id = " . $userdata['user_id'] : "";
$sql = "DELETE FROM " . TOPICS_WATCH_TABLE . " WHERE topic_id = $topic_id" . $delete_sql;
message_die(GENERAL_ERROR, "Couldn't change topic notify data", "", __LINE__, __FILE__, $sql);
if ( $mode == "reply" )
$sql = "SELECT ban_userid
FROM " . BANLIST_TABLE;
message_die(GENERAL_ERROR, "", "", __LINE__, __FILE__, $sql);
$user_id_sql = "";
if ( isset($row['ban_userid']) )
$user_id_sql = ", " . $row['ban_userid'];
$sql = "SELECT u.user_id, u.username, u.user_email, u.user_lang, t.topic_title
FROM " . TOPICS_WATCH_TABLE . " tw, " . TOPICS_TABLE . " t, " . USERS_TABLE . " u
WHERE tw.topic_id = $topic_id
AND tw.user_id NOT IN (" . $userdata['user_id'] . ", " . ANONYMOUS . $user_id_sql . " )
AND tw.notify_status = " . TOPIC_WATCH_UN_NOTIFIED . "
AND t.topic_id = tw.topic_id
AND u.user_id = tw.user_id";
$orig_word = array();
$replacement_word = array();
obtain_word_list($orig_word, $replacement_word);
include($phpbb_root_path . 'includes/emailer.'.$phpEx);
$emailer = new emailer($board_config['smtp_delivery']);
$script_name = preg_replace("/^\/?(.*?)\/?$/", "\\\1", trim($board_config['script_path']));
$script_name = ( $script_name != '' ) ? $script_name . '/viewtopic.'.$phpEx : 'viewtopic.'.$phpEx;
$server_name = trim($board_config['server_name']);
$server_protocol = ( $board_config['cookie_secure'] ) ? "https://" : "http://";
$server_port = ( $board_config['server_port'] <> 80 ) ? ':' . trim($board_config['server_port']) . '/' : '/';
$email_headers = "From: " . $board_config['board_email'] . "
Return-Path: " . $board_config['board_email'] . "
$update_watched_sql = "";
$topic_title = preg_replace($orig_word, $replacement_word, unprepare_message($row['topic_title']));
do
if ( $row['user_email'] != "" )
$emailer->use_template("topic_notify", $row['user_lang']);
$emailer->email_address($row['user_email']);
$emailer->set_subject($lang['Topic_reply_notification']);
$emailer->extra_headers($email_headers);
$emailer->assign_vars(array(
"EMAIL_SIG" => str_replace("<br />", "
" . $board_config['board_email_sig']),
"USERNAME" => $row['username'],
"SITENAME" => $board_config['sitename'],
"U_TOPIC" => $server_protocol . $server_name . $server_port . $script_name . "?" . POST_POST_URL . "=$post_id#$post_id",
"U_STOP_WATCHING_TOPIC" => $server_protocol . $server_name . $server_port . $script_name . "?" . POST_TOPIC_URL . "=$topic_id&unwatch=topic")
$emailer->send();
$emailer->reset();
$update_watched_sql .= ( $update_watched_sql != "" ) ? ", " . $row['user_id'] : $row['user_id'];
if ( $update_watched_sql != "" )
$sql = "UPDATE " . TOPICS_WATCH_TABLE . "
SET notify_status = " . TOPIC_WATCH_NOTIFIED . "
AND user_id IN ($update_watched_sql)";
$db->sql_query($sql);
$sql = "SELECT topic_id
AND user_id = " . $userdata['user_id'];
message_die(GENERAL_ERROR, "Couldn't obtain topic watch information", "", __LINE__, __FILE__, $sql);
if ( !$notify_user && !empty($row['topic_id']) )
if ( !$result = $db->sql_query($sql) )
message_die(GENERAL_ERROR, "Couldn't delete topic watch information", "", __LINE__, __FILE__, $sql);
else if ( $notify_user && empty($row['topic_id']) )
$sql = "INSERT INTO " . TOPICS_WATCH_TABLE . " (user_id, topic_id, notify_status)
VALUES (" . $userdata['user_id'] . ", $topic_id, 0)";
message_die(GENERAL_ERROR, "Couldn't insert topic watch information", "", __LINE__, __FILE__, $sql);
?>[/php]
改成
[php]<?php
function user_notification($mode, &$post_data, &$forum_id, &$topic_id, &$post_id, &$notify_user, $replyby='')
\n $delete_sql = ( !$post_data['first_post'] && !$post_data['last_post'] ) ? " AND user_id = " . $userdata['user_id'] : "";
$user_id_sql = "";
do
"USERNAME" => $row['username'],\r
"REPLY_BY" => $replyby,
$emailer->send();
$emailer->reset();
?>[/php]
然後在 posting.php 找\r
[php]<?php
user_notification($mode, $post_data, $forum_id, $topic_id, $post_id, $notify_user);
?>[/php]
改成
[php]<?php
user_notification($mode, $post_data, $forum_id, $topic_id, $post_id, $notify_user, $userdata['username']);
?>[/php]
試試看, RC3可以用, 原理是一樣的
[php]<?php
$user_id_sql = "";
do
$emailer->send();
$emailer->reset();
?>[/php]
改成
[php]<?php
$user_id_sql = "";
do
$emailer->send();
$emailer->reset();
?>[/php]
然後在 posting.php 找\r
[php]<?php
?>[/php]
改成
[php]<?php
?>[/php]
試試看, RC3可以用, 原理是一樣的
Yeah, OK.OOHOO 寫:function user_notification($mode, &$post_data, &$forum_id, &$topic_id, &$post_id, &$notify_user)
終於搞定
謝謝南宮搏士的細心指點
感激不盡\r
