不小心修改到emailer.php-會員註冊後即出現如下一串鬼東西
yslians
註冊時間: 2007-09-07 19:04
文章 由 yslians »
●架設主機作業系統:Linux
●安裝的程式:Apache + php + MySql
●phpBB2 版本:phpBB 2.0.2
●phpBB2 連結網址: http://www.fosheng.org.tw/php/
請問有沒有原始檔可以覆蓋回去
或是如何處理
?php /*************************************************************************** emailer.php ------------------- begin : Sunday Aug. 12, 2001 copyright : (C) 2001 The phpBB Group email : support@phpbb.com $Id: emailer.php,v 1.15.2.35 2005/10/05 17:42:04 grahamje Exp $ ***************************************************************************/ /*************************************************************************** * * This program is free software; you can redistribute it and/or modify * it under the terms of the GNU General Public License as published by * the Free Software Foundation; either version 2 of the License, or * (at your option) any later version. * ***************************************************************************/ // // The emailer class has support for attaching files, that isn't implemented // in the 2.0 release but we can probable find some way of using it in a future // release // class emailer { var $msg, $subject, $extra_headers; var $addresses, $reply_to, $from; var $use_smtp; var $tpl_msg = array(); function emailer($use_smtp) { $this->reset(); $this->use_smtp = $use_smtp; $this->reply_to = $this->from = ''; } // Resets all the data (address, template file, etc etc to default function reset() { $this->addresses = array(); $this->vars = $this->msg = $this->extra_headers = ''; } // Sets an email address to send to function email_address($address) { $this->addresses['to'] = trim($address); } function cc($address) { $this->addresses['cc'][] = trim($address); } function bcc($address) { $this->addresses['bcc'][] = trim($address); } function replyto($address) { $this->reply_to = trim($address); } function from($address) { $this->from = trim($address); } // set up subject for mail function set_subject($subject = '') { $this->subject = trim(preg_replace('#[\n\r]+#s', '', $subject)); } // set up extra mail headers function extra_headers($headers) { $this->extra_headers .= trim($headers) . "\n"; } function use_template($template_file, $template_lang = '') { global $board_config, $phpbb_root_path; if (trim($template_file) == '') { message_die(GENERAL_ERROR, 'No template file set', '', __LINE__, __FILE__); } if (trim($template_lang) == '') { $template_lang = $board_config['default_lang']; } if (empty($this->tpl_msg[$template_lang . $template_file])) { $tpl_file = $phpbb_root_path . 'language/lang_' . $template_lang . '/email/' . $template_file . '.tpl'; if (!@file_exists(@phpbb_realpath($tpl_file))) { $tpl_file = $phpbb_root_path . 'language/lang_' . $board_config['default_lang'] . '/email/' . $template_file . '.tpl'; if (!@file_exists(@phpbb_realpath($tpl_file))) { message_die(GENERAL_ERROR, 'Could not find email template file :: ' . $template_file, '', __LINE__, __FILE__); } } if (!($fd = @fopen($tpl_file, 'r'))) { message_die(GENERAL_ERROR, 'Failed opening template file :: ' . $tpl_file, '', __LINE__, __FILE__); } $this->tpl_msg[$template_lang . $template_file] = fread($fd, filesize($tpl_file)); fclose($fd); } $this->msg = $this->tpl_msg[$template_lang . $template_file]; return true; } // assign variables function assign_vars($vars) { $this->vars = (empty($this->vars)) ? $vars : $this->vars . $vars; } // Send the mail out to the recipients set previously in var $this->address function send() { global $board_config, $lang, $phpEx, $phpbb_root_path, $db; // Escape all quotes, else the eval will fail. $this->msg = str_replace ("'", "\'", $this->msg); $this->msg = preg_replace('#\{([a-z0-9\-_]*?)\}#is', "' . $\\1 . '", $this->msg); // Set vars reset ($this->vars); while (list($key, $val) = each($this->vars)) { $$key = $val; } eval("\$this->msg = '$this->msg';"); // Clear vars reset ($this->vars); while (list($key, $val) = each($this->vars)) { unset($$key); } // We now try and pull a subject from the email body ... if it exists, // do this here because the subject may contain a variable $drop_header = ''; $match = array(); if (preg_match('#^(Subject:(.*?))$#m', $this->msg, $match)) { $this->subject = (trim($match[2]) != '') ? trim($match[2]) : (($this->subject != '') ? $this->subject : 'No Subject'); $drop_header .= '[\r\n]*?' . preg_quote($match[1], '#'); } else { $this->subject = (($this->subject != '') ? $this->subject : 'No Subject'); } if (preg_match('#^(Charset:(.*?))$#m', $this->msg, $match)) { $this->encoding = (trim($match[2]) != '') ? trim($match[2]) : trim($lang['ENCODING']); $drop_header .= '[\r\n]*?' . preg_quote($match[1], '#'); } else { $this->encoding = trim($lang['ENCODING']); } if ($drop_header != '') { $this->msg = trim(preg_replace('#' . $drop_header . '#s', '', $this->msg)); } $to = $this->addresses['to']; $cc = (count($this->addresses['cc'])) ? implode(', ', $this->addresses['cc']) : ''; $bcc = (count($this->addresses['bcc'])) ? implode(', ', $this->addresses['bcc']) : ''; // Build header $this->extra_headers = (($this->reply_to != '') ? "Reply-to: $this->reply_to\n" : '') . (($this->from != '') ? "From: $this->from\n" : "From: " . $board_config['board_email'] . "\n") . "Return-Path: " . $board_config['board_email'] . "\nMessage-ID: <" . md5(uniqid(time())) . "@" . $board_config['server_name'] . ">\nMIME-Version: 1.0\nContent-type: text/plain; charset=" . $this->encoding . "\nContent-transfer-encoding: 8bit\nDate: " . date('r', time()) . "\nX-Priority: 3\nX-MSMail-Priority: Normal\nX-Mailer: PHP\nX-MimeOLE: Produced By phpBB2\n" . $this->extra_headers . (($cc != '') ? "Cc: $cc\n" : '') . (($bcc != '') ? "Bcc: $bcc\n" : ''); // Send message ... removed $this->encode() from subject for time being if ( $this->use_smtp ) { if ( !defined('SMTP_INCLUDED') ) { include($phpbb_root_path . 'includes/smtp.' . $phpEx); } $result = smtpmail($to, $this->subject, $this->msg, $this->extra_headers); } else { $empty_to_header = ($to == '') ? TRUE : FALSE; $to = ($to == '') ? (($board_config['sendmail_fix']) ? ' ' : 'Undisclosed-recipients:;') : $to; $result = @mail($to, $this->subject, preg_replace("#(?msg), $this->extra_headers); if (!$result && !$board_config['sendmail_fix'] && $empty_to_header) { $to = ' '; $sql = "UPDATE " . CONFIG_TABLE . " SET config_value = '1' WHERE config_name = 'sendmail_fix'"; if (!$db->sql_query($sql)) { message_die(GENERAL_ERROR, 'Unable to update config table', '', __LINE__, __FILE__, $sql); } $board_config['sendmail_fix'] = 1; $result = @mail($to, $this->subject, preg_replace("#(?msg), $this->extra_headers); } } // Did it work? if (!$result) { message_die(GENERAL_ERROR, 'Failed sending email :: ' . (($this->use_smtp) ? 'SMTP' : 'PHP') . ' :: ' . $result, '', __LINE__, __FILE__); } return true; } // Encodes the given string for proper display for this encoding ... nabbed // from php.net and modified. There is an alternative encoding method which // may produce lesd output but it's questionable as to its worth in this // scenario IMO function encode($str) { if ($this->encoding == '') { return $str; } // define start delimimter, end delimiter and spacer $end = "?="; $start = "=?$this->encoding?B?"; $spacer = "$end\r\n $start"; // determine length of encoded text within chunks and ensure length is even $length = 75 - strlen($start) - strlen($end); $length = floor($length / 2) * 2; // encode the string and split it into chunks with spacers after each chunk $str = chunk_split(base64_encode($str), $length, $spacer); // remove trailing spacer and add start and end delimiters $str = preg_replace('#' . preg_quote($spacer, '#') . '$#', '', $str); return $start . $str . $end; } // // Attach files via MIME. // function attachFile($filename, $mimetype = "application/octet-stream", $szFromAddress, $szFilenameToDisplay) { global $lang; $mime_boundary = "--==================_846811060==_"; $this->msg = '--' . $mime_boundary . "\nContent-Type: text/plain;\n\tcharset=\"" . $lang['ENCODING'] . "\"\n\n" . $this->msg; if ($mime_filename) { $filename = $mime_filename; $encoded = $this->encode_file($filename); } $fd = fopen($filename, "r"); $contents = fread($fd, filesize($filename)); $this->mimeOut = "--" . $mime_boundary . "\n"; $this->mimeOut .= "Content-Type: " . $mimetype . ";\n\tname=\"$szFilenameToDisplay\"\n"; $this->mimeOut .= "Content-Transfer-Encoding: quoted-printable\n"; $this->mimeOut .= "Content-Disposition: attachment;\n\tfilename=\"$szFilenameToDisplay\"\n\n"; if ( $mimetype == "message/rfc822" ) { $this->mimeOut .= "From: ".$szFromAddress."\n"; $this->mimeOut .= "To: ".$this->emailAddress."\n"; $this->mimeOut .= "Date: ".date("D, d M Y H:i:s") . " UT\n"; $this->mimeOut .= "Reply-To:".$szFromAddress."\n"; $this->mimeOut .= "Subject: ".$this->mailSubject."\n"; $this->mimeOut .= "X-Mailer: PHP/".phpversion()."\n"; $this->mimeOut .= "MIME-Version: 1.0\n"; } $this->mimeOut .= $contents."\n"; $this->mimeOut .= "--" . $mime_boundary . "--" . "\n"; return $out; // added -- to notify email client attachment is done } function getMimeHeaders($filename, $mime_filename="") { $mime_boundary = "--==================_846811060==_"; if ($mime_filename) { $filename = $mime_filename; } $out = "MIME-Version: 1.0\n"; $out .= "Content-Type: multipart/mixed;\n\tboundary=\"$mime_boundary\"\n\n"; $out .= "This message is in MIME format. Since your mail reader does not understand\n"; $out .= "this format, some or all of this message may not be legible."; return $out; } // // Split string by RFC 2045 semantics (76 chars per line, end with \r\n). // function myChunkSplit($str) { $stmp = $str; $len = strlen($stmp); $out = ""; while ($len > 0) { if ($len >= 76) { $out .= substr($stmp, 0, 76) . "\r\n"; $stmp = substr($stmp, 76); $len = $len - 76; } else { $out .= $stmp . "\r\n"; $stmp = ""; $len = 0; } } return $out; } // // Split the specified file up into a string and return it // function encode_file($sourcefile) { if (is_readable(phpbb_realpath($sourcefile))) { $fd = fopen($sourcefile, "r"); $contents = fread($fd, filesize($sourcefile)); $encoded = $this->myChunkSplit(base64_encode($contents)); fclose($fd); } return $encoded; } } // class emailer ?>
Fatal error: Cannot instantiate non-existent class: emailer in /raid/vhost/fosheng.org.tw/www/php/includes/usercp_register.php on line 680
yslians
文章 由 yslians »
搞了一晚上
以解決了!
找了原始檔覆蓋掉就好了!
