[問題]誰有subBlack3D的中文圖示?
phpBB 2 Style Support
大佬
文章: 260
註冊時間: 2003-11-30 13:38
來自: Kluang,Johor,Malaysia
文章 大佬 »
先說聲謝謝
希望有的人能夠分享
如果小弟解答有錯誤請其他大大修正吧!
●免費空間連結:來看看吧!
●您的 phpBB2 版本:phpBB 2.0.8
sakamoto
文章: 350
註冊時間: 2003-02-13 17:36
來自: scratch
文章 sakamoto »
大佬
文章: 260
文章 大佬 »
Thanks :-D
*****SPAM***** :-o this is made by mac
如果小弟解答有錯誤請其他大大修正吧!
●免費空間連結:來看看吧!
Mac
百戰天龍馬蓋先
百戰天龍馬蓋先
文章: 2590
註冊時間: 2003-02-02 02:28
來自: MacphpBBMOD
文章 Mac »
I made a whole set of FI's buttons for all FI themes
~Mac
大佬
文章: 260
文章 大佬 »
Mac 寫:I made a whole set of FI's buttons for all FI themes
~Mac
*****SPAM***** , now i just know these are all ur "product" :mrgreen:
如果小弟解答有錯誤請其他大大修正吧!
●免費空間連結:來看看吧!
Mac
百戰天龍馬蓋先
百戰天龍馬蓋先
文章: 2590
來自: MacphpBBMOD
文章 Mac »
Some BIG5 button sets on Forumimages are not made by me because those Authors submit earlier than me, However, I do have the whole set with the same font.
Those made by me will be posted again when new-竹貓 is properly setup. (They have been posted before in the old 下載中心)
~Mac
大佬
文章: 260
文章 大佬 »
mac , does FI series' buttons can use on Sub series' ?
My one is SubBlack 3D ver.2 but not FiSubBlack 8-)
如果小弟解答有錯誤請其他大大修正吧!
●免費空間連結:來看看吧!
Mac
百戰天龍馬蓋先
百戰天龍馬蓋先
文章: 2590
來自: MacphpBBMOD
文章 Mac »
Should be the same isn't it?
Check on the filenames or meanings of those images
~Mac
大佬
文章: 260
文章 大佬 »
It is different in some image
like : usergroup , profile , register something
如果小弟解答有錯誤請其他大大修正吧!
●免費空間連結:來看看吧!
Mac
百戰天龍馬蓋先
百戰天龍馬蓋先
文章: 2590
來自: MacphpBBMOD
文章 Mac »
Where did you download SubBlack 3D ver.2? Any demo?
~Mac
大佬
文章: 260
文章 大佬 »
http://myforum.iwebland.com/download/pa ... egory&id=1
I download SubBlack 3D Ver2 from here (third)
如果小弟解答有錯誤請其他大大修正吧!
●免費空間連結:來看看吧!
Mac
百戰天龍馬蓋先
百戰天龍馬蓋先
文章: 2590
來自: MacphpBBMOD
文章 Mac »
Well, all I can say is, wait for someone to do the Chinese button for you, or switch to FI theme
Honestly speaking, FI subBlack 3D button look better than this one. This SubBlack 3D's button is too common. I believe the design is from VBB button set, nothing original about it
~Mac
大佬
文章: 260
文章 大佬 »
so i just use the Fi button for this ?
如果小弟解答有錯誤請其他大大修正吧!
●免費空間連結:來看看吧!
Mac
百戰天龍馬蓋先
百戰天龍馬蓋先
文章: 2590
來自: MacphpBBMOD
文章 Mac »
I don't know how it will look or if it will look good.
If you are going to use FI's buttons, I'll suggest you use FI subBlack 3D theme
~Mac
回到「風格問題討論」
