我想在首頁設定可以讓使用者直接切換的方式換風格\r
例如:
http://wbbrowser.net/phpbb_style/select_style.php
[問題]請問風格如何在首頁直接切換
這個我有裝
你可以在phpbbhacks找到這個mod
我只提供mod,不負責其它的問題唷
## EasyMod 0.0.10 compliant
## Mod Title: change style on index / counts users mod
## Mod Version: 1.1.5
## Author: Tom Cioffe Jr < gwyd@cioffe.com >
## MOD Description: Allows the user / guest to change the style on the index page
## Lots of credits to: Cees-Jan Kiewiet < webmaster@iceblow.zzn.com >
## This mod is based on Cess-Jan Kiewiet's change guest template mod. If a user is logged in,
## their choice of template is stored in a cookie for 6 hours. Otherwise,
## the logged in user's choice in inputted directly into the database.
## Version 1.1 adds a security fix. Thanks to Smartor of smartor.is-root.com for finding this
## fix and alerting me to it.
## Version 1.1.5 updates the MOD's compliance with later versions of phpBB and also EasyMod.
## Thanks goes to gurukast for these changes.
## This mod is for phpBB2 ver. 2.x
## Installation rated: easy-medium
## Installation time: aprox 5-10 min (for editing templates)
## Files to edit: 5
## common.php
## index.php
## includes/functions_selects.php
## language/lang_main.php
## templates/Subsilver/index_body.tpl
## Installation Notes:
## The most important thing to keep in mind is, take your time, make
## sure you are finding the correct lines to modify, then take care to paste the new code.
## Please also keep in mind, if you are using more than one language file or theme at your
## site, you will need to edit the corrosponding files for each occurrence. Good Luck!
#################################################################我只提供mod,不負責其它的問題唷
