[問題] I need permission from ioptical.com (iCGstation template)
phpBB 2 Style Support
nuketools
註冊時間: 2005-01-04 10:08
文章 由 nuketools »
Hi, everybody.
First of all, I don't know Chinese to read and write.
I tried to adopt some portion of codes structures to modify my phpBB theme pack based on iCGstation. However, I sent my mails and PM to Ray (http://www.ioptical.com) A LOT!!!!
Unfortunately, I did not get response from Ray yet.
Do anyone know how to get his permission to adopt his template codes and structures? (images are not).
Please respond to me.
Mac
百戰天龍馬蓋先
百戰天龍馬蓋先
文章: 2590
註冊時間: 2003-02-02 02:28
來自: MacphpBBMOD
文章 由 Mac »
If you are using the theme for your OWN USE, there's no restriction to what you do with it. However, is there is any copyright attached to the theme (i.e. outputed to the browser or not), you have to keep it.
~Mac
nuketools
[討論] Hi, Mac.
文章 由 nuketools »
No, that is not what I asked.
OK, this is my story.
I downloaded iCGstation theme-pack for phpnuke not for phpbb from http://www.portedmods.com. They said, Ray (ioptional.com) allowed them to port it to phpnuke.
I have been using this theme-pack with my credit such as "ioptional.com" at the bottom of phpnuke portal. That's OK.
I made my own phpBB theme-pack from this phpnuke iCGstation theme-pack NOT DIRECTLY FROM iCGstation template of phpBB2.
While making my own first template, I found iCGstation concept is so cool. So, I adopted iCGstation concept and it's in Beta under GPL 2.0 license to let all phpBB persons use free. After making it, I found some source template structure is almost same as iCGstation template, even though I added a lot of my template code. Also, there is no same graphics except concepts. So, my conclusion is that I feel I have to put copyrighted message in my free GPL template to give my credit to Ray.
This is the reason of why I have to contact with Ray to get permission about the concept that I adopted.
Mac
百戰天龍馬蓋先
百戰天龍馬蓋先
文章: 2590
來自: MacphpBBMOD
文章 由 Mac »
I believe image is the only thing that you can't claim it your own, the rest of it should be made GPLed, hence you are free to modified and distribute the code as long as you credit the original author in your distribution (with or without notified teh author).
But, of course, it is a good practise to let him know first. So, you may contact him through PM. He might not notice this post :)
http://phpbb-tw.net/phpbb/profile.php?m ... le&u=18960
http://phpbb-tw.net/phpbb/privmsg.php?mode=post&u=18960
~Mac
nuketools
[問題] Thanks a lot Mac.
文章 由 nuketools »
Thank you for your kind repsonses.
I am trying to contact with him but not yet, no response.
Yes, you're right. The images which I made are totally new ones. And I am using different filenames which affects the whole template codes.
So, after recoding all of them, I'd like to him (Ray) to check if he feels some of them are his. Otherwise, I will put my credit to respect his work in that I adopted his shaded bar concepts into my Aqua concept.
Anyhow, would you let him know I'm looking for him when you see him.
THANKS MILLION!!
Mac
百戰天龍馬蓋先
百戰天龍馬蓋先
文章: 2590
來自: MacphpBBMOD
文章 由 Mac »
Hi, I don't think we visit the forum at the same time, just drop him a PM is the best option I think, or try his MSN :)
~Mac
.::藍色的天空::.
文章: 587
註冊時間: 2003-09-14 17:29
來自: 我不知道
文章 由 .::藍色的天空::. »
Sorry i havn't check my PM and e-mail well, you can modify your phpBB theme pack based on my style (iCGstation), but do not remove any think about copyright, thank you :D
i-Web System 隨坊出來耶
新聞:
遊戲區開幕啦! 打造隨城最強的遊戲王國!
宣傳車出動! 賣力宣傳隨坊吧!
版主召募!版主魂激發!
中文好好學,不要方言通天飛
i-Web System 正式版上架測試!
nuketools
[問題] Hi, Ray.!!
文章 由 nuketools »
Hi, Ray. Finally I gotta ya!
Yes, of course.
As long as I modifed your template codes, I HAVE TO keep my credit for your work.
As such modification keeps going on, probably, future template will not be similar to yours. Then, they are different ones.
However, as I mentioned above, as long as I am working on your codes, I absolutely keep the words.
This is my the first work (sorry I did not put the credit words, this is totally tenative one so don't worry about it) which you can look at. Or you and I declare it to phpBB.com as either of clones or new one, depending on how I recoded it. Just look at the first look of the template.
URL: http://phpbb2.nukekorea.net/AquaBrown
This aquabrown template based on your iCGstation template codes in large part. But the future second template will have none of your template. However, I will keep readme file to mention these series of Aqua template stem from your iCGstation template.
回到「風格問題討論」
