[問題]如何單獨改變分區文字的字級和顏色
phpBB 2 Style Support
brianfang
文章: 78
註冊時間: 2005-10-17 11:06
來自: 妳來自那顆星
文章 由 brianfang »
如何單獨改變分區文字的字級和顏色(紅框處)
在後台試了一下
好像和版面文字是連動的
請問要如何修改
●架設主機作業系統:Linux Server
●使用版本:phpBB 2.0.17
jwxinst
文章: 945
註冊時間: 2006-03-31 10:07
文章 由 jwxinst »
改動css檔案就可以啦
目前狀態圖檔
GoKo Music進度: 10%
新手必讀
問問題的技巧
MOD安裝教學及轉碼
brianfang
文章: 78
來自: 妳來自那顆星
文章 由 brianfang »
jwxinst 寫:改動css檔案就可以啦
我是用預設的風格
如果要改紅框處的字型和顏色
請問要改那一段
粗黑體的字型代碼是什麼
/* General font families for common tags */
font,th,td,p { font-family: Verdana, Arial, Helvetica, sans-serif }
a:link,a:active,a:visited { color : #006699; }
a:hover { text-decoration: underline; color : #DD6900; }
hr { height: 0px; border: solid #D1D7DC 0px; border-top-width: 1px;}
/* This is the border line & background colour round the entire page */
.bodyline { background-color: #FFFFFF; border: 1px #98AAB1 solid; }
/* This is the outline round the main forum tables */
.forumline { background-color: #FFFFFF; border: 2px #006699 solid; }
/* Main table cell colours and backgrounds */
td.row1 { background-color: #EFEFEF; }
td.row2 { background-color: #DEE3E7; }
td.row3 { background-color: #D1D7DC; }
This is for the table cell above the Topics, Post & Last posts on the index.php page
By default this is the fading out gradiated silver background.
However, you could replace this with a bitmap specific for each forum
td.rowpic {
background-image: url(images/cellpic2.jpg);
background-repeat: repeat-y;
/* Header cells - the blue and silver gradient backgrounds */
th {
color: #FFA34F; font-size: 11px; font-weight : bold;
background-color: #006699; height: 25px;
background-image: url(images/cellpic3.gif);
td.cat,td.catHead,td.catSides,td.catLeft,td.catRight,td.catBottom {
background-image: url(images/cellpic1.gif);
background-color:#D1D7DC; border: #FFFFFF; border-style: solid; height: 28px;
Setting additional nice inner borders for the main table cells.
The names indicate which sides the border will be on.
Don't worry if you don't understand this, just ignore it :-)
td.cat,td.catHead,td.catBottom {
height: 29px;
border-width: 0px 0px 0px 0px;
th.thHead,th.thSides,th.thTop,th.thLeft,th.thRight,th.thBottom,th.thCornerL,th.thCornerR {
font-weight: bold; border: #FFFFFF; border-style: solid; height: 28px; }
td.row3Right,td.spaceRow {
background-color: #D1D7DC; border: #FFFFFF; border-style: solid; }
th.thHead,td.catHead { font-size: 12px; border-width: 1px 1px 0px 1px; }
th.thSides,td.catSides,td.spaceRow { border-width: 0px 1px 0px 1px; }
th.thRight,td.catRight,td.row3Right { border-width: 0px 1px 0px 0px; }
th.thLeft,td.catLeft { border-width: 0px 0px 0px 1px; }
th.thBottom,td.catBottom { border-width: 0px 1px 1px 1px; }
th.thTop { border-width: 1px 0px 0px 0px; }
th.thCornerL { border-width: 1px 0px 0px 1px; }
th.thCornerR { border-width: 1px 1px 0px 0px; }
/* The largest text used in the index page title and toptic title etc. */
.maintitle,h1,h2 {
font-weight: bold; font-size: 22px; font-family: "Trebuchet MS",Verdana, Arial, Helvetica, sans-serif;
text-decoration: none; line-height : 120%; color : #000000;
/* General text */
.gen { font-size : 12px; }
.genmed { font-size : 11px; }
.gensmall { font-size : 10px; }
.gen,.genmed,.gensmall { color : #000000; }
a.gen,a.genmed,a.gensmall { color: #006699; text-decoration: none; }
a.gen:hover,a.genmed:hover,a.gensmall:hover { color: #DD6900; text-decoration: underline; }
/* The register, login, search etc links at the top of the page */
.mainmenu { font-size : 11px; color : #000000 }
a.mainmenu { text-decoration: none; color : #006699; }
a.mainmenu:hover{ text-decoration: underline; color : #DD6900; }
●使用版本:phpBB 2.0.17
問題狂
文章: 1947
註冊時間: 2004-06-28 17:13
文章 由 問題狂 »
我記得各區的顏色都是共通的
死寫在CSS中...好像無法一次只更改一個
不過文字顏色倒是可以改
在後台編輯分區名稱的時候加個顏色語法進去就可以了
kkt
文章: 625
註冊時間: 2005-06-15 01:37
來自: H.K.
文章 由 kkt »
To:brianfang
假如你要單獨改變分區文字的字級和顏色, 有幾個方法
除了在基本組態更改, 也可打開 overall_body.tpl
你現在的標題文字色碼是#006699
建議你到下址參考色碼, 然後改好上傳看看便知道.
http://home.pchome.com.tw/net/jiemike37/css.html
而粗體字是 bold;
要每個標題顏色不一樣, 可直接在後台設定標題文字時, 用 html 寫入.
例如:
&nbsp;<font color="red">MAIN 站務區 (FORUMS)</font>
前面的&nbsp;是留空格, 太貼了, 你可自行多加上.
red 你可改為你要的色碼, 例如: <font color="#FF0000">
祝你成功!! ;-)
在此學到很多架站知識, 永遠多謝:
brianfang
文章: 78
來自: 妳來自那顆星
文章 由 brianfang »
問題狂 寫:我記得各區的顏色都是共通的
不過文字顏色倒是可以改
分區文字是用類似這樣的HTML語嗎< font color="#rrggbb" >文字< /font >
試過了好像沒什麼用
連簽名檔也沒辨法用HTML語法
後台有開啟呀
●使用版本:phpBB 2.0.17
brianfang
文章: 78
來自: 妳來自那顆星
文章 由 brianfang »
kkt 寫:To:brianfang
你現在的標題文字色碼是#006699
而粗體字是 bold;
例如:
祝你成功!! ;-)
< font size=3 face="bold" color="#rrggbb" >文字 < /font >
改顏色可以了
但顏色加字型好像就不行了
●使用版本:phpBB 2.0.17
kkt
文章: 625
來自: H.K.
文章 由 kkt »
brianfang, 其實你最方便的一個做法, 是先在 overall_body.tpl 內,
把其中一或兩項字型類別, 更改為你要的色碼, 利用 css 的統一風格屬性.
再在後台把你要的主題這樣輸入 (當然是個別啦, 如果整體調整干脆改 css 檔)
<a class="maintitle">主題</a
<a class="nav">主題</a>
當然你可改變更多的屬性, 如:
gen
gensmall
genmed
等等都可以, 不妨隨便試試, 有"備"便無患了, 我自己也是這樣嘗試過來.
ps. 你上面的語法錯了, 要同時設定字型, 字體, 字色是:
<span style="font-size: 5pt" color="red"><b>主題</b></span>
有很多方法寫的, 不能一概而論, 隨機應變. 祝你修改順利.. ;-)
在此學到很多架站知識, 永遠多謝:
jwxinst
文章: 945
文章 由 jwxinst »
我是用預設的風格
是指官方的subsilver嗎?
那個css已經沒用了耶....
-_-"只好用 css美化外掛來灰復他的css管理功能
蠻正統XDDDD :mrgreen:
不曉得他的是否 subsilver呢?
如果是, 應該沒法用 css....
我也不曉得了= ="
目前狀態圖檔
GoKo Music進度: 10%
新手必讀
問問題的技巧
MOD安裝教學及轉碼
brianfang
文章: 78
來自: 妳來自那顆星
文章 由 brianfang »
有些語法可以用在「分區文字」
但是不能用在「文章標題」
也不能用在簽名檔
語法好像不是通用的
後台的html語法有開呀
●使用版本:phpBB 2.0.17
kkt
文章: 625
來自: H.K.
文章 由 kkt »
brianfang, 首先想請問你第一篇的問題解決了沒有?
正常情況下「分區文字」及「文章標題」, 的語法一樣.
也毋須開啟後台的html, 也不建議開放. 很易被在 [簽名檔] 植入破壞程式.
在此學到很多架站知識, 永遠多謝:
jwxinst
文章: 945
文章 由 jwxinst »
你是否用 subsilver?
如果是你可以去用外掛[css 美化]灰復 css功能
這樣子就能簡單地運用
請參考這一篇
http://phpbb-tw.net/phpbb/viewtopic.php?p=218164#218164
因為 phpBB 某些預設的字實在是太小了,我想要修改 subSilver 字形大小,哪知道 subSilver.css 不管怎麼改通通沒用
目前狀態圖檔
GoKo Music進度: 10%
新手必讀
問問題的技巧
MOD安裝教學及轉碼
brianfang
文章: 78
來自: 妳來自那顆星
文章 由 brianfang »
kkt 寫:brianfang, 首先想請問你第一篇的問題解決了沒有?
分區文字已經用你提供的方法
已經改變顏色成功了
用同樣的方法
在發文的標題就沒辨法使用
http://www.c4d.twmail.org/viewforum.php?f=28
不知道是不是我裝了主題類型MOD才會這樣
後台的HTML現在也關閉
謝謝你的提醒
●使用版本:phpBB 2.0.17
kkt
文章: 625
來自: H.K.
文章 由 kkt »
To: brianfang, 因為版面的主題跟後台設定的不一樣.
假如你經常要設定主題色, 建議你安裝 [外掛] Topic Color Hack (修改標題顏色)
http://phpbb-tw.net/phpbb/viewtopic.php?t=38856
在此學到很多架站知識, 永遠多謝:
回到「風格問題討論」
