[外掛]推薦網站簡易版外掛
Officially Approved MODs
由 phpBB Group 官方發展小組認證的 MOD!
oO]-[Oo
南宮博士
南宮博士
文章: 512
註冊時間: 2001-11-11 18:09
來自: TAIWAN
文章 由 oO]-[Oo »
炎.. 來幫我試一下
推薦網站簡易版
已知BUG.. 在mozila下無法正常顯示, 想辦法解決中\r
## Mod Title: Links_MOD
## Mod Version: 1.1.0
## Author: OOHOO < webdev@phpbb-tw.net > http://phpbb-tw.net/
## Description: Display links (with logo) on the forum index page.
## Installation Level: (easy)
## Installation Time: 1-5 Minutes
## Files To Edit:
## index.php
## language/lang_chinese_traditional_taiwan/lang_main.php
## templates/subSilver/index_body.tpl
## Included Files:
## links.js.php
## includes/links_constants.php
## templates/subSilver/links_js_body.tpl
## images/links/web_logo88a.gif
## images/links/phpBB_88a.gif
## images/links/phpbb-tw_logo88a.gif
## Security Disclaimer: This MOD Cannot Be Posted To Or Added At Any Non-Official phpBB Sites
## Author Note: Simple version
## Version History:
## 1.0.X - 2002/03/22 - for phpBB RC serial, and was named Related_Links_MOD
## 1.1.0 - 2002/04/25 - Re-packed for phpBB 2.0.0, and renamed to Links_MOD
請先下載[url=http://phpbb-tw.net/phpbb/download/links_mod_simple.zip]links_mod_simple.zip[/url], 將檔案解至以下位置\r
links.js.php
[color=red](註. 請自行在 images/ 底下建立 links子目錄)[/color]
#-----[ ACTION: OPEN  ]------------------------------------------
index.php
#-----[ ACTION: FIND ]------------------------------------------
#-----[ ACTION: AFTER, ADD ]------------------------------------------
include($phpbb_root_path . "includes/links_constants.$phpEx"); // Links_MOD
'L_ONLINE_EXPLAIN' => $lang['Online_explain'],
'L_LINKS' => $lang['Site_links'], // Links_MOD
'U_SITE_LOGO' => SITE_LOGO_SRC, // Links_MOD
'SITE_LOGO_WIDTH' => SITE_LOGO_WIDTH, // Links_MOD
'SITE_LOGO_HEIGHT' => SITE_LOGO_HEIGHT, // Links_MOD
<!-- BEGIN switch_user_logged_out -->
<form method="post" action="{S_LOGIN_ACTION}">
#-----[ ACTION: BEFORE, ADD ]------------------------------------------
<table width="100%" cellpadding="3" cellspacing="1" border="0" class="forumline">
	<td class="catLeft" width="100%" height="22"><span class="cattitle">{L_LINKS}</span></td>
	<td class="catRight" nowrap="nowrap" align="center"><span class="cattitle">{SITENAME}</span></td>
	<td class="row1" nowrap="nowrap"><iframe marginwidth="0" marginheight="0" src="links.js.php" frameborder="0" scrolling="no" width="100%" height="{SITE_LOGO_HEIGHT}"></iframe></td>
	<td class="row2" nowrap="nowrap"><img src="{U_SITE_LOGO}" alt="{SITENAME}" width="{SITE_LOGO_WIDTH}" height="{SITE_LOGO_HEIGHT}" border="0" /></td>
</table>
#-----[ ACTION: ADD ]------------------------------------------
// Related links
$lang['Site_links'] = "推薦網站";
#-----[ ACTION: CHANGE  ]------------------------------------------
define('SITE_URL', "http://phpbb-tw.net/");
define('SITE_LOGO_SRC', "http://phpbb-tw.net/phpbb/images/links/web_logo88a.gif");
[color=red](註.請自行設定 SITE_URL ==> 網站位置, SITE_LOGO_SRC ==> logo 位置)[/color]
加入連結資料, 格式範例如下
$LINKS = array(
	array('link_title' => 'phpBB 官方網站', 'link_logo_src' => 'images/links/phpBB_88a.gif', 'link_url' => 'http://www.phpbb.com/'),
	array('link_title' => '竹貓星球', 'link_logo_src' => 'images/links/phpbb-tw_logo88a.gif', 'link_url' => 'http://phpbb-tw.net/'),
define('DISPLAY_INTERVAL', 6000); // 輪播間隔 (豪秒)
define('DISPLAY_LOGO_NUM', 8); // LOGO顯示數量
#-----[ ACTION: SAVE & CLOSE FILE ]------------------------------------------
最後由 oO]-[Oo 於 2002-05-12 03:40 編輯,總共編輯了 1 次。
OOHOO said:
有事Mail給我, 不要P我, 因為根本沒辦法P.
御津闇慈
文章: 645
註冊時間: 2001-11-17 10:59
文章 由 御津闇慈 »
剛剛起來*_______*||||
我等等試試看
這麼多黨+_____+|||
御津闇慈
文章: 645
文章 由 御津闇慈 »
恩~剛剛用囉~~出現錯誤@@在index.php那邊@@|||
我訴建議先用我前面低方式~~修改index_body.tpl就好~~
links.js.php 的背景色也沒顯示出來+________+|||
御津闇慈
文章: 645
[外掛]稍微完整的推介簡易版
文章 由 御津闇慈 »
打開index_body.tpl
尋找\r
下面加入...
    <p align="center"><span class="cattitle">推薦網站</span></td>
    [color=#ff0033]你的網站名稱[/color]</span></td>
\n   <td class="row1" nowrap="nowrap"><iframe marginwidth="0" marginheight="0" src="links.js.php" frameborder="0" scrolling="no" width="100%" height="31"></iframe></td>
    <img src="[color=#ff0019]logo連結[/color]" alt="[color=#ff0019]網站名稱[/color]" width="88" height="31" border="0" /></td>
</table>
再來把OOHOO兄公佈的
links.js.php
放上去\r
並且修改includes/links_constants.php 就好
#-----[ ACTION: CHANGE ]------------------------------------------ \r
加入連結資料, 格式範例如下
$LINKS = array(
因為拆來拆去比較麻煩~~而且我剛剛裝有出現錯誤@@|||所以就改成這樣~~
frank
文章: 170
註冊時間: 2001-11-20 09:48
來自: 跑跑好好玩
文章 由 frank »
我用OOHOO的
沒問題
但是我想知道
在推薦網站最右邊
我想放法蘭庫克的連結圖
要去哪改阿???
templates/subSilver/links_js_body.tpl嗎??
但好像沒看到說~
重出江湖
跑跑好好玩
http://runrun.tw
Rappelz-TW
第九封印
http://runrun.tw/Rappelz/phpBB3/index.php
御津闇慈
文章: 645
文章 由 御津闇慈 »
frank 寫:我用OOHOO的
沒問題
但是我想知道
在推薦網站最右邊
我想放法蘭庫克的連結圖
要去哪改阿???
但好像沒看到說~
找~~links_constants.php
oO]-[Oo
南宮博士
南宮博士
文章: 512
來自: TAIWAN
文章 由 oO]-[Oo »
Frank, 改這個
define('SITE_URL', "http://phpbb-tw.net/"); // 你的網站url
define('SITE_LOGO_SRC', "http://phpbb-tw.net/phpbb/images/links/web_logo88a.gif"); // 你的網站LOGO
綠草上的小水滴
文章: 25
註冊時間: 2002-04-22 17:37
來自: 秘室裡的春天
文章 由 綠草上的小水滴 »
請問 OOHOO博士\r
改了之後只有訪客可以看到\r
註冊會員卻見不到\r
而且背景顏色跟我的 templates 不合
請問這要如何改?
oO]-[Oo
南宮博士
南宮博士
文章: 512
來自: TAIWAN
文章 由 oO]-[Oo »
綠草上的小水滴 寫:請問 OOHOO博士\r
改了之後只有訪客可以看到\r
註冊會員卻見不到\r
請問這要如何改?
那就是你改錯了, 你再檢查一次吧..(應該是 ACTION: BEFORE, ADD 那步錯了,
BEFORE, ADD是加在上面不是加在後面)
背景顏色你可以直接改links_js_body.tpl 裡的 background-color:{T_BODY_BGCOLOR}"
LancerEvo
文章: 31
註冊時間: 2002-02-23 15:48
文章 由 LancerEvo »
御津闇慈 寫:恩~剛剛用囉~~出現錯誤@@在那邊@@|||
我也是裝好以後出現錯誤在index.php
會不會是裝其他MOD的關係阿?
還是我改錯@_@
綠草上的小水滴
文章: 25
來自: 秘室裡的春天
文章 由 綠草上的小水滴 »
已經 ok 了
但是那個連結的背景顏色還是白色的..
怎麼改都沒成功
請問可以詳細說明一下改法嗎
謝謝!
oO]-[Oo
南宮博士
南宮博士
文章: 512
來自: TAIWAN
文章 由 oO]-[Oo »
LancerEvo 寫:
會不會是裝其他MOD的關係阿?
還是我改錯@_@
是怎樣的錯誤??
綠草上的小水滴 寫: 但是那個連結的背景顏色還是白色的..
怎麼改都沒成功
就是links_js_body.tpl 的 background-color:{T_BODY_BGCOLOR}"
改成
background-color:你要的顏色"
或是進控制台>>風格管理>>管理選項>>subSilver 編輯>>資料格顏色一
改成你的背景色... 你是不是有改過風格了??
綠草上的小水滴
文章: 25
來自: 秘室裡的春天
文章 由 綠草上的小水滴 »
我是改過風格...
但我不是改 subsilver 下的 "links_js_body.tpl"
而是改我風格的 links_js_body.tpl
將 background-color:{T_BODY_BGCOLOR}"
改成 background-color:{#2E425A}"
也一樣不行
都會顯示成白色的
ps:推薦網站預設二個..其餘地方為白色..跟templates很不合
綠草上的小水滴
文章: 25
來自: 秘室裡的春天
文章 由 綠草上的小水滴 »
試成功了..
進入控制台後...將資料格顏色二設為背景顏色即可\r
謝謝 OOHOO博士的指導!
kuloo
竹貓好朋友
竹貓好朋友
文章: 142
註冊時間: 2002-01-19 01:29
來自: 就是那個光.......
文章 由 kuloo »
我也是照OOHOO博士滴去改,OK!! (:Y)
但是有一個地方\r
include($phpbb_root_path . "includes/links_constants.$phpEx"); Links_MOD
要加" // "
include($phpbb_root_path . "includes/links_constants.$phpEx"); [color=red]//[/color]Links_MOD
好像才不會有錯誤.....
壹 . 文章篇數多與寡 , 非表自身之程度 , 有效助人為優先 , 耐心用心最重要 .
貳 . 問題很多不可恥 , 就怕發問沒規矩 , 入境隨俗最重要 , 自然有人會幫您 .
叁 . 初來乍到無所謂 , 閒聊之間學東西 , 善用搜尋為第一 , 對話用語要適宜 .
回到「官方認證外掛」
