Author: Balint
MOD Description: Places "Administration Panel"-link on top of the page. Only visible for admins.
MOD Version: 1.0.4 (updated: 08/18/03)
Installation Level: Easy
Installation Time: ~ 5 Minutes
Download File: adminpanel_link_mod_1.0.4.zip
File Size: 2303 Bytes
這個mod在頁面上方的控制列也擺一個「進入系統管理控制台」連結
注意: 部分程式碼已修改為lang_chinese_traditional_taiwan的路徑
## MOD Title: Administration Panel-link in navigation
## MOD Author: Balint < balint@krizsan.de > (Balint Krizsan) http://phpbb.krizsan.de
## MOD Description: Places "Administration Panel"-link on top of the page.
## Only visible for admins.
## MOD Version: 1.0.4
## Installation Level: Easy
## Files To Edit: includes/page_header.php,
## templates/subSilver/overall_header.tpl,
## language/lang_english/lang_main.php
## Included Files: icon_mini_admin.gif
## Author Notes:
## THIS SOFTWARE IS PROVIDED BY THE AUTHOR 'AS IS' AND ANY
## EXPRESSED OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED
## TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS
## FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL
## THE AUTHOR OR ITS CONTRIBUTORS BE LIABLE FOR ANY DIRECT,
## INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
## DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
## SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR
## PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON
## ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
## LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
## ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF
## ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
## MOD History:
## 2003-08-11 - Version 1.0.4
## - cosmetical stuff in overall_header.tpl
## - removed additional version and images
## 2003-02-17 - Version 1.0.3
## - possibility to include just image without text (idea: JetJam)
## 2003-02-07 - Version 1.0.2
## - updated for 2.0.4
## - shorter link text (thanks to JetJam)
## - possibility to include just image without text (thanks to JetJam)
## 2002-09-13 - Version 1.0.1
## - fixed image display bug (thanks to JetJam)
## 2002-08-06 - Version 1.0.0
## - Initial Release
copy icon_mini_admin.gif to templates/subSilver/images/icon_mini_admin.gif
// Parse and show the overall header.
$l_admin_top_link = ( $userdata['user_level'] == ADMIN ) ? '<a class="mainmenu" href="admin/index.' . $phpEx . '?sid=' . $userdata['session_id'] . '"><img src="templates/subSilver/images/icon_mini_admin.gif" width="12" height="13" border="0" hspace="3" />' . $lang['Admin_panel_top'] . '</a>' : '';
'L_USERNAME' => $lang['Username'],
'L_ADMIN_TOP_LINK' => $l_admin_top_link,
<td height="25" align="center" valign="top" nowrap="nowrap"><span class="mainmenu"> <a href="{U_PROFILE}" class="mainmenu"><img src="templates/subSilver/images/icon_mini_profile.gif" width="12" height="13" border="0" alt="{L_PROFILE}" hspace="3" />{L_PROFILE}</a> <a href="{U_PRIVATEMSGS}" class="mainmenu"><img src="templates/subSilver/images/icon_mini_message.gif" width="12" height="13" border="0" alt="{PRIVATE_MESSAGE_INFO}" hspace="3" />{PRIVATE_MESSAGE_INFO}</a> <a href="{U_LOGIN_LOGOUT}" class="mainmenu"><img src="templates/subSilver/images/icon_mini_login.gif" width="12" height="13" border="0" alt="{L_LOGIN_LOGOUT}" hspace="3" />{L_LOGIN_LOGOUT}</a> </span></td>
<td align="center"><span class="mainmenu">{L_ADMIN_TOP_LINK}</span></td>
// That's all, Folks!
$lang['Admin_panel_top'] = '進入系統管理控制台';
# EoM如果你希望頁面下方的「進入系統管理控制台」也要有扳手小圖示\r
可以這麼改:
#-----[ 編輯 ]------------------------------------------
templates/subSilver/overall_footer.tpl
<div align="center"><span class="copyright"><br />{ADMIN_LINK}<br />
#-----[ 將其註解起來 ]------------------------------------------
<!-- 上面那一段 -->
#-----[ 然後新增這行 ]------------------------------------------
<div align="center"><span class="mainmenu"><br />{L_ADMIN_TOP_LINK}<br />
