[外掛] Welcome & Avatar On Index
Officially Approved MODs
由 phpBB Group 官方發展小組認證的 MOD!
櫻田社長
文章: 92
註冊時間: 2003-06-16 21:14
來自: 戀愛櫻之社
文章 櫻田社長 »
## EasyMod 0.0.9 compliant
## MOD Title: Welcome & Avatar On phpBB Index
## MOD Author: AbelaJohnB < abela@phpbb.com > (John B. Abela) http://www.JohnAbela.Com/
## MOD Description: This MOD will place a 'welcome your_name' and your avatar
##   (if you have one) within the 'who is online' section of the index page.
##   If you do not have an avatar, it will display the default 'whosonline.gif'
## MOD Version: 3.0.3
## Installation Level: Easy
## Installation Time: ~10 minutes
## Files To Edit:
##                   index.php
##                   includes/functions.php
##                   language/lang_english/lang_main.php
##                   templates/subSilver/index_body.tpl
## Included Files: n/a
## Author Notes:
## Copyright ?John B. Abela, < abela@johnabela.com >
## I do not support my MOD's anywhere except http://www.phpBB.com/ or my own site,
## (in full or partial format). If you intend to take my work and add to it, you must retain my
## above Copyright and notify me of your actions via email.
## ~ John B. Abela - (aka: AbelaJohnB) http://www.johnabela.com/  - abela@phpbb.com
##   Stop By And Sign My Guestbook If You Feel Like It :)
## MOD History:
##   2003-07-05 - Version 3.0.3
##      - Added new function to get users template (might be useful for other mod authors!)
##      - Made EasyMod 0.0.9 Compliant, as best as I can tell.
##   2003-06-21 - Version 3.0.2
##      - Bug Fix: $profiledata != $userdata <sigh>
##\r
##   2003-06-17 - Version 3.0.1
##      - Updated for phpBB 2.0.5
##   2003-06-09 - Version 3.0.0
##      - Rewrote for phpBB2.0.4+
##   2002-05-12 - Version 1.0.0
##      - Initial Release
## MOD Localisation:
##  N/A
index.php
		'body' => 'index_body.tpl')
    // START MOD: Avatar On Index  - AbelaJohnB
    $avatar_img = '';
    if ( $userdata['user_avatar_type'] && $userdata['user_allowavatar'] )
        switch( $userdata['user_avatar_type'] )
            case USER_AVATAR_UPLOAD:
                $avatar_img = ( $board_config['allow_avatar_upload'] ) ? '<img src="' . $board_config['avatar_path'] . '/' . $userdata['user_avatar'] . '" alt="" border="0" />' : '';
                break;
            case USER_AVATAR_REMOTE:
                $avatar_img = ( $board_config['allow_avatar_remote'] ) ? '<img src="' . $userdata['user_avatar'] . '" alt="" border="0" />' : '';
                break;
            case USER_AVATAR_GALLERY:
                $avatar_img = ( $board_config['allow_avatar_local'] ) ? '<img src="' . $board_config['avatar_gallery_path'] . '/' . $userdata['user_avatar'] . '" alt="" border="0" />' : '';
                break;
    if ($avatar_img == '')
        // Set up style
        if ( !$board_config['override_user_style'] )
            if ( $userdata['user_id'] != ANONYMOUS && $userdata['user_style'] > 0 )
                $template_name = get_template_name($board_config['default_style']);
                $avatar_img = '<img src="'. $phpbb_root_path . 'templates/' . $template_name . '/images/whosonline.gif" >';
            $avatar_img = '<img src="templates/subSilver/images/whosonline.gif" >';
    // Check For Anonymous User
    if ($userdata['user_id'] != '-1')
        $name_link = '<a href="' . append_sid("profile.$phpEx?mode=editprofile&" . $userdata['user_id']) . '" />' . $userdata['username'] . '</a>';
    {\r
        $name_link = $lang['Guest'];
    // END MOD: Avatar On Index  - AbelaJohnB
        'L_NAME_WELCOME' => $lang['Welcome'],
        'U_NAME_LINK' => $name_link,
        'AVATAR_IMG' => $avatar_img,
function encode_ip($dotquad_ip)
// Get Template Value
function get_template_name($style)
	global $db, $board_config, $template, $images, $phpbb_root_path;
	$sql = "SELECT template_name
		FROM " . THEMES_TABLE . "
		WHERE themes_id = $style";
		message_die(CRITICAL_ERROR, 'Could not query database for theme info');
	if ( !($row = $db->sql_fetchrow($result)) )
		message_die(CRITICAL_ERROR, "Could not get theme data for themes_id [$style]");
	$template_name = $row['template_name'] ;
	return $template_name;
$lang['Welcome_subject'] = 'Welcome to %s Forums'; // Welcome to my.com forums
$lang['Welcome'] = "Welcome"; // Welcome
	<td class="row1" align="center" valign="middle" rowspan="2"><img src="templates/subSilver/images/whosonline.gif" alt="{L_WHO_IS_ONLINE}" /></td>
	<td class="row1" align="center" valign="middle" rowspan="2"><span class="mainmenu">{L_NAME_WELCOME}</span><BR /><span class="mainmenu">{U_NAME_LINK}</span><BR /><BR />{AVATAR_IMG}</td>
# EoM
●上網方式:HGC VDSL (Upload/download 10M)
●使用 phpBB2 版本:phpBB 2.0.8a
●自架Server (appserv-win32-2.4.0 + WinServer2003)
●您的 phpBB2 連結網址: http://www.atbbadboys.com
[建議] 修正
Source: http://phpbb-tw.net/phpbb/viewtopic.php?p=242537#242537
#-----[ OPEN ]-----
index.php
#-----[ FIND ]-----
        $name_link = '<a href="' . append_sid("profile.$phpEx?mode=editprofile&u=" . $userdata['user_id']) . '" />' . $userdata['username'] . '</a>';
#-----[ SAVE & CLOSE ]-----
ps.
官方討論主題:
http://www.phpbb.com/phpBB/viewtopic.php?t=111698
回到「官方認證外掛」
