## MOD Title: Random Style for Guests
## MOD Author: DavidIQ < david@davidiq.com > (David Colon) http://www.davidiq.com
## MOD Description: This mod will set a random style for guests.
## MOD Version: 1.0.1
## Installation Level: Easy
## Installation Time: 1 Minute
## Files To Edit: includes/functions.php,
## Included Files: N/A
## License: http://opensource.org/licenses/gpl-license.php GNU General Public License v2
## For security purposes, please check: http://www.phpbb.com/mods/
## for the latest version of this MOD. Although MODs are checked
## before being allowed in the MODs Database there is no guarantee
## that there are no security problems within the MOD. No support
## will be given for MODs not found within the MODs Database which
## can be found at http://www.phpbb.com/mods/
## Author Notes: Random style will be selected every 15 minutes for guest.
## MOD History:
## 2006-3-25 - Version 1.0.0
## - Mod creation
## 2006-4-19 - Version 1.0.1
## - Changed $_COOKIE to $HTTP_COOKIE_VARS
$theme = setup_style($board_config['default_style']);
//BEGIN Random Styles for Guests MOD
if (isset($HTTP_COOKIE_VARS[$board_config['cookie_name'].'_rand_style']))
$rand_style = $HTTP_COOKIE_VARS[$board_config['cookie_name'].'_rand_style'];
$theme = setup_style($rand_style);
global $db;
$sql = "SELECT *
FROM " . THEMES_TABLE . "
ORDER BY RAND() LIMIT 1";
message_die(CRITICAL_ERROR, 'Could not query database for theme info');
if ( !($row = $db->sql_fetchrow($result)) )
message_die(CRITICAL_ERROR, "Could not get theme data for themes_id [$style]");
$rand_style = $row['themes_id'];
setcookie($board_config['cookie_name'].'_rand_style', $rand_style, (time()+900), $board_config['cookie_path'], $board_config['cookie_domain'], $board_config['cookie_secure']);
//END Random Styles for Guests MOD
# EoM版本: 1.0.1
時間: ~ 1 Minute
檔案: Random_Style_for_Guests_1.mod
大小: 2833 Bytes
