[外掛] 快速編輯文章 Quick Edit Mod 1.1.3
Officially Approved MODs
由 phpBB Group 官方發展小組認證的 MOD!
taicomjp
文章: 32
註冊時間: 2004-08-19 00:00
文章 由 taicomjp »
[2.0.19] Quick Edit Mod
## MOD Title: Quick Edit Mod
## MOD Author: valik_90 < valik.90@mail.ru > (Valentin Politov) http://www.phpBB.com.md/
## MOD Description: A popup-box for faster editing posts.
## MOD Version: 1.1.3
## Installation Level: Easy
## Files To Edit: 4
##		viewtopic.php
##		language/lang_english/lang_main.php
##		templates/subSilver/viewtopic_body.tpl
##		templates/subSilver/overall_header.tpl
## Included Files: (n/a)
## License: http://opensource.org/licenses/gpl-license.php GNU General Public License v2
## For security purposes, please check: http://www.phpbb.com/mods/
## for the latest version of this MOD. Although MODs are checked
## before being allowed in the MODs Database there is no guarantee
## that there are no security problems within the MOD. No support
## will be given for MODs not found within the MODs Database which
## can be found at http://www.phpbb.com/mods/
## Author Notes:
## MOD History:
##   2006-01-29 - Version 1.1.3
##      - Fix the form of Quick Edit Box
##   2005-04-15 - Version 1.1.2
##      - Fix usage problem between Advanced Quick Reply MOD and Quick Reply MOD
##   2005-04-13 - Version 1.1.1
##      - Added signiture button
##   2005-04-12 - Version 1.0.1
##      - The strengthening demonstrated
##   2005-04-11 - Version 1.0.0
##      - inititla release
lang_main.php
// Quick Edit Mod
$lang['Quick_edit'] = '快速編輯';
$lang['Close'] = '關閉';
$lang['Attach_sign'] = "附上簽名";
版本: 1.1.3
等級: 容易
時間: ~ 5 分鐘
檔案: quick_edit_mod_1.1.3.zip
大小: 2238 Bytes
回到「官方認證外掛」
