(由於語系翻譯中可能存有差異,我會在一天內更新,並以 (更新)通告!!!)
這個是從phpBB官方網站裡找到的2.0.20外掛,個人翻譯中文化是因為覺得這個外掛蠻不錯。
比如說像我個人發表「phpBB新手通」,一直都得在自己的論壇裡先草擬好,再重新把代碼(編輯)貼到竹貓裡,這可是有點麻煩了。
這個外掛可以讓你固定在自己的論壇,像E-MAIL的草稿夾一樣,把你認為還不能公開 (incomplete)的新文章隱藏起來。
外掛名稱: 發表草稿箱
下載點:
http://www.phpbb.com/phpBB/viewtopic.php?t=223319
## MOD Title: Save posts as drafts
## MOD Author: asinshesq < N/A > (Alan) N/A
## MOD Description: Allow users to save their posts or pms as drafts so they can begin a post or pm
## and finish it later. Since it is a draft, others will not see it until it is done.
## MOD Version: 1.0.24
## Installation Level: Easy
## Installation Time: 20 Minutes ( 1 minute with easymod)
## Files To Edit: posting.php
## viewforum.php
## viewtopic.php
## privmsg.php
## search.php
## admin/admin_forum_prune.php
## admin/index.php
## includes/constants.php
## includes/topic_review.php
## includes/functions_post.php
## includes/functions_admin.php
## includes/prune.php
## includes/page_header.php
## language/lang_english/lang_main.php
## language/lang_english/lang_admin.php
## templates/subSilver/admin/forum_prune_select_body.tpl
## templates/subSilver/admin/index_body.tpl
## templates/subSilver/index_body.tpl
## templates/subSilver/posting_body.tpl
## templates/subSilver/search_results_posts.tpl
## templates/subSilver/search_results_topics.tpl
## Included Files: N/A
## License: http://opensource.org/licenses/gpl-license.php GNU General Public License v2
## For security purposes, please check: http://www.phpbb.com/mods/
## for the latest version of this MOD. Although MODs are checked
## before being allowed in the MODs Database there is no guarantee
## that there are no security problems within the MOD. No support
## will be given for MODs not found within the MODs Database which
## can be found at http://www.phpbb.com/mods/
## Author Notes: If you have the attachments mod installed on your board, install this mod first and then afterwards
## install the mod set forth in "mod_to_save_posts_as_drafts_to_allow_for_attachments.txt"
## If you want to add links to drafts on non-standard pages (e.g. in the private message area or,
## for that matter, in viewforum or viewtopic), here is the code you would use (this gets assigned
## in page_header so you can stick those links on pretty much any page you want):
## To add a link called "View your topics and drafts", insert this in the
## template page on which you want the link to appear:
## <a href="{U_SEARCH_SELF_BY_TOPIC}" class="gensmall">{L_SEARCH_SELF_BY_TOPIC}</a>
## To add a link called "View your posts and drafts", insert this in the
## <a href="{U_SEARCH_SELF_BY_POST}" class="gensmall">{L_SEARCH_SELF_BY_POST}</a>
## You can add one or both or neither (I personally don't like the view your topics and drafts so
## I got rid of that link everywhere but suit yourself)
## MOD History:
## 2006-04-09 - Version 1.0.24
## made changes needed if installing this mod on a phpbb 2.0.20 (no other changes made)
##1. 新增+執行SQL語法
#-----[ SQL ]-------------------------------------------------
ALTER TABLE phpbb_posts ADD post_draft smallint(1) unsigned NOT NULL default '0';
CREATE TABLE phpbb_draft_prune (
prune_id tinyint(1) unsigned NOT NULL default '1',
prune_days smallint(5) unsigned NOT NULL default '0',
prune_freq smallint(5) unsigned NOT NULL default '0',
prune_next int(11) unsigned NOT NULL default '0',
prune_enable tinyint(1) unsigned NOT NULL default '0'
INSERT INTO phpbb_draft_prune (prune_id, prune_days, prune_freq) VALUES(1, 90, 10);2. 修改檔案 [EDIT]
3. 此外掛沒有包括任何 included files (不用上傳檔案)
*4. 如果已經裝置了Files Attchment MOD, 請必需要執行 /contrib/mod_to_save_posts_as_drafts_to_allow_for_attachments.txt
正體中文語系化
1. language/lang_chinese_traditional_taiwan/lang_main.php
$lang['Critical_Error'] = '重大錯誤';
#-----[ AFTER, ADD ]-----------------------------------------
// start mod save draft posts
$lang['Search_your_drafts_and_topics'] = '檢視目前你發表的草稿主題';
$lang['Search_your_drafts_and_posts'] = '檢視目前你未發表的草稿';
$lang['Draft_posts'] = '草稿';
$lang['Topics_you_have_posted_to'] = '已發表的主題';
$lang['Your_posts'] = '你的文章';
$lang['Draft_post_time'] = '草稿儲存時間';
$lang['Draft_post_subject'] = '草稿文章';
$lang['Draft_post_topic'] = '草稿的主題';
$lang['Draft_post_forum'] = '位置';
$lang['Save_as_draft'] = '另存為草稿';
// end mod save draft posts2. language/lang_chinese_traditional_taiwan/lang_admin.php
#-----[ OPEN ]-------------------------------------------------
#-----[ FIND ]-------------------------------------------------
#-----[ BEFORE, ADD ]-------------------------------------------------
// start mod save posts as drafts ... added teh following variables for pruning and auto pruning of drafts
$lang['Drafts'] = '草稿';
$lang['Draft_prune'] = '編輯草稿';
$lang['Draft_topics_pruned'] = '主題編輯';
$lang['Draft_posts_pruned'] = '文章編輯';
$lang['Draft_pruning_successful'] = '編輯成功!';
$lang['Draft_auto-prune'] = '草稿自動整理模組 <br /> (必需要由系統控制台裡允許啟動)';
$lang['Auto_prune_settings_changed'] = '自動整理模組的設定更新成功!';
$lang['Remove_drafts_not_modified'] = '移除未被整理的草稿 ';
$lang['Check_draft_age'] = '以草稿的時間排列 ';
$lang['Number_of_drafts'] = '草稿數量';
$lang['Drafts_per_user'] = '草稿上限';
// end mod save posts as drafts
