測試狀況: 這外掛裝後要每次在登入時選擇是否隱藏, 而登出後個人資料的隱藏被預設為否.
## MOD Title: Hidden Login MOD
## MOD Author: eviL3 < evil@ut4e.com > (Igor Wiedler) http://evil.ut4e.com/
## MOD Description: Allows users to login Hidden, so they aren't listed in
## the "who's online" part.
## MOD Version: 0.1.3
## Installation Level: Easy
## Installation Time: 3 Minutes
## Files To Edit:
## includes/page_header.php
## login.php
## language/lang_english/lang_main.php
## templates/subSilver/index_body.tpl
## templates/subSilver/login_body.tpl
## Included Files: (n/a)
## Author Notes:
## I know that olympus has something like this. But i had the Idea already
## before i saw it in phpbb3 beta1. Thanks to noobarmy who also had this Idea :)
## I'd also like to thank Kalipo who gave me some good tipps :)
## MOD History:
## 2006-06-20 - Version 0.1.0
## - First release
## 2006-06-21 - Version 0.1.1
## - Small lang addition
## - If not hidden, log in unhidden
## 2006-06-21 - Version 0.1.2
## - Template fixes
## - Don't show when logging into admin
## 2006-06-21 - Version 0.1.3
## - Fix resetting when logging into admin
#-----[ OPEN ]------------------------------------------------
'L_AUTO_LOGIN' => $lang['Log_me_in'],
#-----[ AFTER, ADD ]------------------------------------------------
'L_HIDE_LOGIN' => $lang['Hidden_login'],
'L_HIDE_LOGIN_LONG' => $lang['Hidden_login_long'],
// Allow autologin?
#-----[ BEFORE, ADD ]------------------------------------------------
$template->assign_block_vars('switch_allow_hidelogin', array());
login.php
$autologin
$hidelogin = ( isset($HTTP_POST_VARS['hidelogin']) ) ? TRUE : 0;
// Reset login tries
$db->sql_query
// Hidelogin
if( !$userdata['session_logged_in'] )
if( $hidelogin )
$db->sql_query('UPDATE ' . USERS_TABLE . ' SET user_allow_viewonline = 0 WHERE user_id = ' . $row['user_id']);
$db->sql_query('UPDATE ' . USERS_TABLE . ' SET user_allow_viewonline = 1 WHERE user_id = ' . $row['user_id']);
$lang['Log_me_in']
$lang['Hidden_login'] = 'Hide';
$lang['Hidden_login_long'] = 'Log me in as hidden';
<!-- END switch_allow_autologin -->
{L_HIDE_LOGIN}
<input class="text" type="checkbox" name="hidelogin" />
<!-- BEGIN switch_allow_hidelogin -->
<tr align="center">
<td colspan="2"><span class="gen">{L_HIDE_LOGIN_LONG}: <input type="checkbox" name="hidelogin" /></span></td>
<!-- END switch_allow_hidelogin -->
#-----[ SAVE/CLOSE ALL FILES ]--------------------------------
# EoM
語系檔中文部份:
#-----[ 打開 ]------------------------------------------------
$lang['Log_me_in']
$lang['Hidden_login'] = '隱藏';
$lang['Hidden_login_long'] = '隱藏在線狀態';
ps. 如不需在首頁顯示隱藏選項, index_body.tpl 的部份可以略過.
