[外掛] Anti-bot Guest Post Mod (防止訪客機器人發文) (Update 1.1.0)
Officially Approved MODs
由 phpBB Group 官方發展小組認證的 MOD!
文章: 8536
檔頭說明:
## MOD Title: Anti-bot Guest Post Mod
## MOD Author: otseng < N/A > (Oliver Tseng) http://debatingchristianity.com
## MOD Description: This MOD makes it a little bit harder
##                  for a robot to make an anonymous posting.
##                  It will ask to select a dropdown to confirm
##                  an anonymous post.
## MOD Version: 1.0.1
## Installation Level: Easy
## Installation Time: <5 Minutes
## Files To Edit:
##               posting.php
##               templates/subSilver/posting_body.tpl
##               language/lang_english/lang_main.php
## Included Files: n/a
## License: http://opensource.org/licenses/gpl-license.php GNU General Public License v2
## For security purposes, please check: http://www.phpbb.com/mods/
## for the latest version of this MOD. Although MODs are checked
## before being allowed in the MODs Database there is no guarantee
## that there are no security problems within the MOD. No support
## will be given for MODs not found within the MODs Database which
## can be found at http://www.phpbb.com/mods/
## Author Notes:
##   The MOD will install using EasyMOD
##   MOD dev thread:
##   http://www.phpbb.com/phpBB/viewtopic.php?t=264103
##   This MOD was in response to the following topic:
##   http://www.phpbb.com/phpBB/viewtopic.php?t=263469
##   Demo is available at:
##   http://debatingchristianity.com/forum/viewtopic.php?t=1300
## MOD History:
##   2005-02-17 - Version 0.0.1
##  	- Beta release
##   2006-01-20 - Version 1.0.0
##  	- General release
##   2006-01-25 - Version 1.0.1
##  	- Replaced hard coded values
外掛描述:
此外掛, 利用新增一個 '選項' 的欄位, 防止機器人順利發文.
http://www.phpbb.com/phpBB/viewtopic.php?t=361339
最後由 心靈捕手 於 2006-12-09 11:02 編輯,總共編輯了 1 次。
文章: 8536
[建議] 升級 1.1.0
檔頭說明:
##                  It will add a textbox to confirm
## MOD Version: 1.1.0
## Files To Edit:
##               posting.php
## Author Notes:
##   MOD dev thread:
## MOD History:
##  	- Beta release
##   2006-10-25 - Version 1.1.0
##  	- Replaced dropdown with textbox
外掛描述:
此外掛, 利用新增一個 '輸入文字' 的欄位, 防止機器人順利發文.
http://www.phpbb.com/phpBB/viewtopic.ph ... 34#2531834
文章: 8536
[分享] 中文化參考
1.0.1 版中文化參考
// Anti-bot Guest Post Mod
$lang['Confirm_post'] = '訪客發文確認?';
$lang['Confirm_post_explain'] = '訪客發文, 請選擇 "是"';
$lang['Confirm_post_error'] = '訪客發文, 請在 "訪客發文確認?" 選擇 "是"';
1.1.0 版中文化參考
// 請自行建立一個說明通關密語的檔案 (guests.html), 並修改相關路徑
$lang['Confirm_post'] = '通關密語';
$lang['Confirm_post_explain'] = '訪客發文, 請輸入通關密語';
$lang['Confirm_post_error'] = '錯誤的通關密語. 請參考 <a href="http://YOUR_WEBSITE/PHPBB_ROOT/guests.html" target="_blank">這裡</a> 輸入通關密語.';
ps.
安裝 1.1.0 版, 若要避免訪客發文 (第一次) 輸入錯誤的通關密語,
則可以進行以下的修改.
$lang['Confirm_post_explain'] = '訪客發文, 請參考 <a href="http://YOUR_WEBSITE/PHPBB_ROOT/guests.html" target="_blank">這裡</a> 輸入通關密語';
DEMO:
http://wang5555.dnsfor.me/phpbb2/posting.ph ... topic&f=35
回到「官方認證外掛」
